10-30-2015, 05:30 PM | #1 |
1967 c10 gas tank
Hello. I have a 67 c10 with the tank behind the seat. It is probably not the original tank. I smell fumes in the cab, so I'm trying to fix it. Got some questions about all the lines. I have the ecc tank because it has the hose going to the inlet.
There are two lines off the fuel tank sending unit. One obviously goes to the engine. The other is just pinched, no cap or anything. What should I do with this other line? Does it need to breathe, or can I cap it? Behind the passenger is another line coming out, this appears to be a vent, just a hose a foot or so long. So, does anyone know what I can do to get the fumes out? I don't see a way to allow the hose behind the passenger to get out of the cab (no holes in the floor). Any help appreciated. |
10-30-2015, 05:42 PM | #2 |
member #16
Re: 1967 c10 gas tank
All a 67 needs is the line to the fuel pump and a vented cap. You can plug the others or get the proper sender.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
10-30-2015, 06:29 PM | #3 |
yeah 67 did not have all those other ports or a hose leading up inside the cab. i would plug them and use a vented cap
1967custom |
10-30-2015, 06:52 PM | #4 |
Thank you gentlemen, I think I will just run a hose from one of the extra ports to the other, since I don't have caps, then buy a vented cap.
