Old 10-30-2015, 06:31 PM   #1
terrylgreenjr
Air Bar info
I have a 91 Suburban and wanting to install air suspension in the rear. I was planning on a C notch and not cutting up the rear floor. I've found a parallel 4 link with the bag behind the axle and was wondering about how much travel they have. Anyone with any experience on this style set up or any other ideas you have I'm open to comments.
terrylgreenjr is offline   Reply With Quote
Old 10-30-2015, 09:30 PM   #2
SCOTI
SCOTI's Avatar
Re: Air Bar info
Travel depends on the bag & shock combo as well as how things are set-up. What kit are you lookin at?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-30-2015, 09:43 PM   #3
SCOTI
SCOTI's Avatar
Re: Air Bar info
Re-post for some reason.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-30-2015, 10:11 PM   #4
terrylgreenjr
Re: Air Bar info
I'm not sure if the photo uploaded because I'm on my phone. But basically the bottom bag mount is part of the 4 link bracket and its right behind the axle. Then you mount the top mount on the outside of the frame rail
Old 10-31-2015, 12:48 AM   #5
Pro Performance
Pro Performance's Avatar
Re: Air Bar info
I have setup a 4-link before, and did similar axle brackets off the rear end. My 4-link didn't have the rear bag mount integrated, but does make for a cleaner look. Here is one that RideTech offers and includes an upper crossmember that you cut to fit for the upper mounts. This one has the bags sitting inside the frame.
http://www.ridetech.com/store/universal-hd-4-link.html
Pro Performance is offline   Reply With Quote
Old 10-31-2015, 12:11 PM   #6
terrylgreenjr
Re: Air Bar info
The major thing I'm trying to find out is how much travel you get out of this style set up. Since you don't have it on a bar or a cantilever for added lift ratio
Old 11-01-2015, 11:15 AM   #7
Pro Performance
This particular setup has 6.5" of lift due to the bag. If you use a different bag like the F9000, then you can get 7.5".
Old 11-02-2015, 10:57 AM   #8
slimneverdies
slimneverdies's Avatar
Re: Air Bar info
I was curious as to what those airbags in this setup are capable of compared to other bags as far as travel goes. I will be pulling a 10,000lbs trailer so I figured those 3500 bags would be what I needed but I want to be able to bring my truck up high as possible.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 11-02-2015, 01:36 PM   #9
SCOTI
SCOTI's Avatar
Re: Air Bar info
The dimensions provided by Firestone for the '3500' bags suggest that there is 2.5" between installed height & max extension. The 'ride height' to max lift on the rear of my dually is only a couple inches so that would seem to support the math.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-02-2015, 02:16 PM   #10
terrylgreenjr
Re: Air Bar info
So if I want more then 6-7 inches of travel I need to go a different route I guess. I'm hoping to run everything on the rear air suspension on the outside of the frame due to the rear fuel tank and exhaust. Maybe a long 2 link outside the frame with panhard bar is the answer
Old 11-02-2015, 02:58 PM   #11
SCOTI
SCOTI's Avatar
Re: Air Bar info
When you say "6-7 inches of travel"..... do you mean you want to be able to lift it 6" above ride height as well as dropping below ride height when desired?
If so, you might look into KP Components rear Cantilever 4-link set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-02-2015, 03:27 PM   #12
slimneverdies
Re: Air Bar info
Thanks for helping with the explanation on this yet I'm still a little confused. So on your truck what's the total number of inches in height you have from completely bagged to full extension? My c30 will be bagged on frame and the tires are 31" tall if that helps.
Long live SLIM
Old 11-02-2015, 03:30 PM   #13
terrylgreenjr
Re: Air Bar info
No I just want to be able to have the pumpkin hit the factory floor and then raise it up to about factory height. I also want to run the bags in the best range for the best ride. I feel like with only 6-7 inches of total bag movement, and with just a c notch. I would only be about 1-1.5 inches from bottoming out the axle when I ran the bag in its sweet spot. Am I wrong about this? thanks for all the info that's coming out on this thread
Old 11-02-2015, 04:17 PM   #14
SCOTI
SCOTI's Avatar
Re: Air Bar info
Approx 6.5".
Min height fully compressed is 6.5". Max extended height is 13" so there's 6.5" of travel between the 2 limits.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-02-2015, 04:22 PM   #15
slimneverdies
Re: Air Bar info
Approx 6.5".
Would a triple bellow bag give a similar ride and weight capacity? I'm running the bag on the front of the axle.
Long live SLIM
Old 11-02-2015, 04:57 PM   #16
SCOTI
SCOTI's Avatar
Re: Air Bar info
Firestone's tapered sleeve bag w/the greater 2,000lb capacity is the F9100's. Their dimensions indicate ~9.75" of total travel:
5.25" Min compressed height
10-10.5 recommended ride height
15" Max extension
This is where the comment I made comes from:
For the 'best' ride you need to be close to the mfr's recommended ride height ('best' is subjective per the individual). Typically you might get your desired ride quality a little above or below that number.
Not all 'kits' are going to yield that dimension depending on where the upper/lower brackets are placed. You need to see what bag the manufacturer of the kit set it up for.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-02-2015, 05:01 PM   #17
SCOTI
SCOTI's Avatar
Re: Air Bar info
I couldn't say. The only triple convo bags I've seen are from ChassisTech/AIM/AirBagIt or whatever & I avoid their product line. Not sure about others.
You still have to keep the shock dimensions in the number crunching as well. It's hard sometimes to find a shock that's in it's sweet spot @ ride height while allowing full extension/compression too.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
