Removing bed from 87 tomorrow, any operating experience appreciated. Any how to's?
I know it's simple I looked at my truck looks to be simply 8 bolts holding the bed to the frame.
I went ahead and sprayed them down good with some KROIL lube to help things out tomorrow. Do you guys typically replace the bed bolts when you do this? I might do this while they're out anyway. Any resource for them better than others? Looks like the part number for the ac delco part for my truck is EP 386 but different sites etc says that not correct etc so if anyone knows for sure the correct oem part please let me know. and just any other things to look out for or sizes of the bolt nuts etc that may help it go a little simpler because I looked the web over and only found bed how to on a 1988 which should be close but I was curious about wiring plug in's etc. **the bed bolts are round on the bed end Looks like they may just turn? thanks ![]() Last edited by weider1717; 10-30-2015 at 08:26 PM. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Removing bed from 87 tomorrow, any operating experience appreciated. Any how to's
be forewarned ALOT of the time the bolts just spin when you try to take them out... I try to move a little back off then go some more easy and lots of lube is the key
three or four guys or some canvas straps and motor hoist /chainfall is the way to lift off the bed Make sure you disconnect the tail light harness and fuel fillers ( id try to remove them before lifting) and it helps to have a buddy to steer the bed away from the cab while doing this
![]() Just like this. You can do it yourself if you have to. I usually have someone stand on the back of the cherry picker because my bed is just a little over the tipping point. But a long bed dually is surely heavier than yours. I've wound up cutting a couple bolts if they spin. Lube them up really good and use a breaker bar instead of an impact to lessen the chance of camming out. Don't cut your wires. There is a plug back by the bumper. |
Moderator
![]() Join Date: Oct 2008
If the bolts even offer to stick I cut em off. Replacements are cheap. No use wallowing out the holes to save $2 in bolts.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
![]() Join Date: Apr 2012
BOLT, Body Hold Down (1/2"-13 x 4 1/4”) ................................ 9 .008
I believe these are the bolts you need. I'd try use your OEM bolts quality 4-1/4 partially threaded carriage bolts are going to be hard to find. |
I always cut bed bolts the local fasner store keeps most any size carriagehead bolt. I have welded nuts to the top side and have someone help hold it with a beaker bar and socket to keep from messing up the bed
If you have a friend to step on the bolts while you loosen them you will lessen your chances of rounding out the holes in the bed. I have never had a problem removing bed bolts up here in rust country. I guess they are fairly well protected from direct salt spray.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Hey guys I got a couple broke loose and notice something goofy with the bolts on my truck.
One of the left fronts where it looks like a long bolt should be there is..it runs down through the bottom of the frame through a hole. However, on the other side right side has a short bolt where it looks to need that same long bolt. I then moved back some and found a long bolt on the right side where on the left side a short one is. can anyone tell me exactly where the longs should go and how many long ones I should have? my truck was repainted by GM under warranty in like 1991 I assume thats when this happened and they just threw the bolts back without caring. Kinda sorry but anyway just want to be sure I'm right on this and where they go. thanks |
The long bolts...at least on a long bed, are the second set from the front. Not sure on a shortbed. But on mine, there's no way that anyone could ever get a short bolt in where the long ones go.
they did on mine! but thanks I figured they shouldn't be mix matched like that.
I have a 86 SWB and there 2 long bolts in the second set of holes from the front. The other 6 bolts are shorter. Had my bed off about 3 times in the last year for one reason or another. Used a Big Red engine hoist a couple of times but the boom was just a little too short. Ended up buying a cheap 1 ton chain hoist and that worked perfectly. Good luck
Guys I have the bolts loosened except 2 in the back those 4 are a pain! I can't deep a deep well 3/4 socket and my 1/2 rachet in between the rails and a shallow 3/4 and a 3//8 rachet bottom out.
Only way i broke one loose was with a 3/4 box in wrench. anyway decided to snap a couple pictures showing how I assume the dealer put the bed bolts in wrong when it was re-painted under GM recall. If you look that short bolt where I think a long should be even has a non shoulder nut on it. Another reason why you're aways better off doing your own work even techs at a dealership feel it's not theirs and who cares as long as the bed is bolted down I guess…but it made it a pain to break that short one loose in that spot. left side 2nd bolt back right side 2nd bolt back. One thing I will say is odd is in the above picture you can see where the nut shoulder has been on this short one where the bolt should be but its not I don't see any markings of a nut ever being there. Maybe the factory messed up and the techs at the dealership just put it back like they found it. Thats far fetched but possibly... |
#13 |
I noticed that when I removed the bed on my 85 Chevy pickup that it had a short bolt where it should have had a long bolt too , another thing is I had to use a torch on a few of the bolts even over the gas tank , lots of water was sprayed on the tank on those two , needless to say I used liberal amounts of copper neverseeze when reinstalling the bolts .
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
#14 |
I use a shallow 3/4 socket and a 32" breaker bar for those rear ones. They can be a *****, but take your time and the breaker bar will do it. I'm assuming that it's the bumper mounts/hitch that are in your way...
#15 |
Most of the one that I've done the nuts are to rusty to even get a wrench on without rounding off yours look brand new to most of the ones I've messed with
#16 | |
#17 | |
During the time I was a production supervisor I ran the area where the pickup box was secured. We did about 900,000 units over that six year period. Keep in mind at 60 jobs per hour the guy in the pit has roughly 45 seconds to secure all those box bolts (plus hang the spare tire and connect the taillight wiring harness). He doesn't have time to fool around getting those nuts started and tight; as such, any place where the top of the C Channel of the frame is obscured (by a crossmember, or exhaust, or both) is potentially a location where the long bolt would be used to drop the attachment into a more accessible spot. Also be advised that the nuts are not finger started before driving; he sets them in the socket of a right angle air tool and pulls the trigger. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-02-2015 at 03:53 PM. |
#18 | |
so sounding more and more like thats the way they came. Any more on this to be sure? because it looks to be made for a long bolt on the right side 2nd bolt back (see pic ) but a lot of people have different. |
#19 | |
1987 R10 Silverado |
#20 | |
http://www.73-87.com/7387info/Assembly%20Line.htm K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-04-2015 at 08:02 AM. |
#21 | |
![]() Keep in mind those components (like crossmembers) are common across multiple option combinations, so for some long wheel base vehicles, or diesels (with dual exhaust), or straight six (where the exhaust goes down the right hand side) there may have been a long bolt in that spot. Just not for us gas burning swb guys. The design has to accommodate all those various possibilities (swb, lwb, crew; 2wd, 4wd, several different powertrains). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-04-2015 at 03:48 PM. |
#22 | |
I would also like to know why or what purpose it makes to have a short bolt there on the right side yet on the left side a long one when the frame looks to be made for long on either side there. Just odd and curious if you knew the reason ![]() thanks for this because I just kNEW they just had the bolts in the wrong location. I knew it was repainted by gm in 1991 I was assuming they had took the bed off then and mixed them up. |
#23 | |||
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-05-2015 at 02:24 PM. |
