1966 Headlight Relays
Need a mini overview of the need for headlight relays when updating to halogen bulbs......Have noticed a wide variety of units at vehicle shows.....some provide MFG logos and specs....others are black mini boxes with no spes's.....what brand is recommended ? Source for units....Suggested diagrams for bright/low mode? Thanks in advance.......
Senior Enthusiast
Re: 1966 Headlight Relays
Here's a thread I did on my 1960 GMC. Nothing fancy, I just used generic parts which have worked fine:
http://67-72chevytrucks.com/vboard/s...light+upgrades
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
In my opinion you should run relays no matter what kind of headlights you run. Full 12 volts of power to the lights. Use the light switch as a "trigger" only to open the relays. Much brighter lights. IMO
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
are you talking about the relay itself? Just go to any local auto parts store and look for a 4 pin Bosch relay.
It should look like this, but may have 5 pins. ![]()
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
