Old 10-31-2015, 11:33 AM   #1
Cheyenne350
Steering wheel removal
Trying to remove my original steering wheel to clean it up but ran into some trouble that i can't take it out. Can someone tell me how too..
Cheyenne350 is offline   Reply With Quote
Old 10-31-2015, 11:47 AM   #2
UKNOWME
UKNOWME's Avatar
Re: Steering wheel removal
Are you using a puller?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 10-31-2015, 12:32 PM   #3
enaberif
You need a puller
enaberif is offline   Reply With Quote
Old 10-31-2015, 01:41 PM   #4
Cheyenne350
Thanks guys on my wait to autozone to get one.
Old 10-31-2015, 11:24 PM   #5
bilfman
bilfman's Avatar
U can use 2 large hammers ( one a ball peen)to do it. Loosen the nut so it is even with the top of the stud(this will prevent nut and stud damage). Put the ball peen hammer under the steering wheel and put the flat of the hammer on the nut. Pull hard on the end of that hammer, basically the handle of the hammer is under the steering wheel and you are providing force to pull the wheel off the stud. While you provide this pressure strike the ball peen hammer with the other hammer, a few strikes should pop it right off . I have used this method for years, a puller does work best but thus works fine in a pinch.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 11-01-2015, 03:08 PM   #6
slotard
You really need a puller. Not too hard to DIY if you have the right bolts.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 11-01-2015, 04:27 PM   #7
kalbert
Just get the right tool and be done with it.
kalbert is offline   Reply With Quote
Old 11-01-2015, 05:15 PM   #8
Cheyenne350
I want to thank all you guys for taking time and advice me to get this done. Did clean the streering wheel but I though this one look nice on it.
Old 11-01-2015, 05:35 PM   #9
UKNOWME
UKNOWME's Avatar
That does look nice. Where did you get it?
1964 Chevy c10
Old 11-01-2015, 05:50 PM   #10
Cheyenne350
Here's the link brothers trucks http://www.brotherstrucks.com/products.asp?dept=1063
