Old 10-31-2015, 05:36 PM   #1
Oldgmc1963
Parking brake
My parking brake doesn't work and hoping someone can instruct me how to adjust or fix it. It appears that everything is all there and maybe could be adjusted if anyone knows how to do that. Thanks in advance.
Oldgmc1963 is offline   Reply With Quote
Old 10-31-2015, 07:23 PM   #2
jayoldschool
Moderator
Re: Parking brake
Just have to follow the path. Cable connected to lever? Cable connected under the cab? Slider moving under cab? Cables connected to slider? Cables connected to backing plates? Take drums off, check connections inside. Adjust...
jayoldschool is offline   Reply With Quote
Old 10-31-2015, 07:50 PM   #3
PGSigns
PGSigns's Avatar
Re: Parking brake
Some more information on your truck will help. Assumption is you have a 63 GMC. Most all these adjust at the end of the cable coming from the handle. Like Jay said though you have to check it all to make sure it is good and in working condition before you can adjust it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-31-2015, 08:16 PM   #4
Oldgmc1963
Re: Parking brake
thank you!
Old 11-01-2015, 11:30 AM   #5
Oldgmc1963
Re: Parking brake
one more question - do you know which direction you would go to adjust?
thanks again.
Old 11-01-2015, 12:53 PM   #6
gar187er
Re: Parking brake
ive been fighting with mine, cant get enough adjustment to allow the pads to grab. Previously I only had about 3-4 clocks of the parking brake, and saw there saw still slack in the cables underneath. I then adjusted the nut on the end of the main cable and now I have 10 clicks but still not enough tension for the back brakes to grab. I changed rear pads, made sure the cables were attached, but still nothing
i think my cables might be strectched (if thats even possible). hopefully yours is easier to figure out.
gar187er is offline   Reply With Quote
Old 11-01-2015, 06:10 PM   #7
Oldgmc1963
Re: Parking brake
got it - thanks.
Old 11-01-2015, 07:09 PM   #8
PGSigns
PGSigns's Avatar
Re: Parking brake
You need to first make sure the rear brakes are adjusted correctly and then run the nut in to take out what ever slack needed to get the handle to pull tight somewhere around half travel.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
