Old 10-31-2015, 08:01 PM   #1
ralewis3
Automatic gear indicator.
New to the forum. Just picked up a '66 GMC stepside long bed yesterday. Originally had a manual transmission but it's been replaced with an automatic. There is no gear indicator on the column though. Any idea of what I need?
ralewis3 is offline   Reply With Quote
Old 10-31-2015, 08:27 PM   #2
DPowers
DPowers's Avatar
Re: Automatic gear indicator.
Pic would help to see what column you have.
DPowers is offline   Reply With Quote
Old 10-31-2015, 08:58 PM   #3
ralewis3
Old 10-31-2015, 08:59 PM   #4
ralewis3
I'm trying but it won't post it for some reason. I'll keep trying.
Old 10-31-2015, 09:11 PM   #5
ralewis3
The only way I can post it is via a link.
https://goo.gl/photos/x1dQHLrSe64aszYB6
Old 10-31-2015, 10:22 PM   #6
DPowers
DPowers's Avatar
A lot of good information in the FAQ section, but it looks like they just used the OEM manual column? Example of an OEM auto column:
Old 10-31-2015, 11:20 PM   #7
LVPhotos
LVPhotos's Avatar
No need! Park, neutral, reverse, drive. Every Chevy or such I owned. Never had to look. Same with manual. Except reverse H pattern and VW.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-31-2015, 11:23 PM   #8
ralewis3
Understood. Just trying to see if I can find out how to do it.
Old 10-31-2015, 11:30 PM   #9
LVPhotos
LVPhotos's Avatar
You get use to the count. 1-2-3, nutral, reverse, drive.
The hard part is explaining to a cop why the speedo needle broke off after he herd you 5 miles down the canyon!
Old 10-31-2015, 11:32 PM   #10
ralewis3
I get that. No problem. What I want to know is how to install the indicator.
Old 10-31-2015, 11:42 PM   #11
LVPhotos
LVPhotos's Avatar
If it's a manual column, no dice!
http://www.ididitinc.com/retrofit-st...ruckCS_Retr-47
Old 10-31-2015, 11:56 PM   #12
Slow Build
Slow Build's Avatar
You might be able to use something like this.
https://www.performanceonline.com/St...-3-or-4-Speed/
I guess it depends on what they mean by "universal". It usually means it doesn't fit anything, but with a little ingenuity it could probably made to work.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-01-2015, 08:48 AM   #13
PGSigns
PGSigns's Avatar
To get an indicator you will need to go to a automatic column. They are a bit hard to find. They do come up in the for sale section but not to often.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-01-2015, 09:59 AM   #14
ralewis3
Jimmy
Thanks Jimmy. That's what I was looking for. Asking around now. Let me know if you ever get one. Don't need the wheel, just the column.
Old 11-01-2015, 11:53 AM   #15
oldusafmsgt
oldusafmsgt's Avatar
I've used the chrome 63-66 indicator housing on manual columns with success. Fabricated a pointer. Also Ididit and others make universal gear indicators that work on just about any column. Only other option is a factory automatic column, which they are somewhat difficult to find, or a floor shifter.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
