Old 11-01-2015, 02:44 PM   #1
catch2otwo
Trailing arm crossmember hardware
Ready to convert my leaf sprung truck to trailing arm. what type of hardware do I use to bolt the crossmember to the frame? How about bolting the trailing arms to the cross member? Thanks
catch2otwo is offline   Reply With Quote
Old 11-02-2015, 07:45 AM   #2
PGSigns
PGSigns's Avatar
Re: Trailing arm crossmember hardware
You can get the trailing arm bolts from several vendors. I have a bolt in cross member for my 65 and the bolts are 3/8 24 X 1 1/4 grade 8 with lock nuts. I'll have to look for the trailing arm bolts to get measurements off those so you could get them from a local fastener supplier.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-03-2015, 02:21 AM   #3
catch2otwo
Cool thanks. Ill do a search, I didn't know vendors were selling kits.
Old 11-03-2015, 09:15 PM   #4
PGSigns
PGSigns's Avatar
Not kits but the replacement trailing arm bolts. LMC has the bolt, nut and washer.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
