Old 11-01-2015, 07:40 PM   #1
72 Longbed
A/C to non a/c firewall difference
Just looking to swap from a/c to heater only and wanted to know if there's a difference in the firewalls
72 Longbed is offline   Reply With Quote
Old 11-01-2015, 07:48 PM   #2
Tdrcreyn4
Tdrcreyn4's Avatar
Re: A/C to non a/c firewall difference
Yes, quite a bit different.
Tdrcreyn4 is offline   Reply With Quote
Old 11-01-2015, 07:53 PM   #3
72 Longbed
Are they major diffeerences and what are they?
Old 11-02-2015, 08:38 PM   #4
48richard
48richard's Avatar
I changed my cab from non-A/C to A/C a few years ago. Look at post #10 in my thread below, and you can see the major differences.
http://67-72chevytrucks.com/vboard/s...d.php?t=382711
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 11-03-2015, 07:28 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: A/C to non a/c firewall difference
Here is the picture of differences.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-05-2015, 04:49 PM   #6
snipescastle2
snipescastle2's Avatar
Talking Re: A/C to non a/c firewall difference
I have templates I made from an old A/C dash to trace out where the duct ball housing go, if you need them.... I can't remember which size hole saw I used, but it worked great! most of the places you need to drill holes on the firewall have dimples where the evaporator housing attaches. Make sure you grab the flapper valve/spring and the vacuum diaphragm/bracket, as well as the little nylon bearing/nut/pivot that the flapper inserts into the cowl vent when you get your a/c parts, they don't make that part anymore,(at least I haven't been able to find a source for it yet)
Good Luck!
Ben
snipescastle2 is offline   Reply With Quote
Old 11-05-2015, 04:50 PM   #7
69Tom
69Tom's Avatar
Ben
I could use these if you wouldn't mind PM'ing them to me. Thanks!
69Tom is offline   Reply With Quote
