11-01-2015, 09:47 PM | #1 |
Wireharness clips on the Frame question
Hey how many wireharness clips are on the Lh frame rail on a 72 Blazer? The ones that both the fuel sending and rear lighting wires clip in to.
Also, does anyone have pics of where they go. I can't seem to find a drawing in the Assembly manual. Thanks. Jeff.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
11-02-2015, 01:28 AM | #2 |
Re: Wireharness clips on the Frame question
There was 3 of them that I pulled off mine
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
11-02-2015, 12:47 PM | #3 |
Here are a couple pics from mine:
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
11-02-2015, 12:53 PM | #4 |
One more:
11-02-2015, 01:41 PM | #5 |
Not sure if these pics will help, but I took these before I took the frame apart.
Edit; Oops, I just realized it was wiring clips you were concerned about and not brake line clips. Those are the only pics I had, sorry. |
11-02-2015, 06:48 PM | #6 |
Maybe someone can actually find the page in the assembly manual, I can'y
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-02-2015, 07:18 PM | #7 | ||
I actually had 7 total and 2 of them were along the rear x-member for the Fuel sending wire. That would leave 5 along the frame rail if I had them all.
Thanks. That helps with a few of them. Quote:
Hopefully someone chimes in who has a survivor truck that has the factory clips still in place.
11-02-2015, 07:35 PM | #8 |
Actually Minnz you've shown 4 different ones on your pics. Mine had 5 remaining along the side when I took it apart if that was all of them there is only one more spot. Don't know if my Bkazer still had them all or not.
11-02-2015, 07:42 PM | #9 |
is this it?
WIN_20151102_183756 by [url=https://www.flickr.com/photos/97391199@N06/] It measures .575 from front of assembly manual
11-02-2015, 07:47 PM | #10 | |
11-02-2015, 08:09 PM | #11 |
Jeff, it says except for G&I-X
11-03-2015, 10:57 AM | #12 |
Ok, I found another pic of a 5th clip. It was located above the driver's rear spring shackle:
11-03-2015, 08:06 PM | #13 |
Well that may be it. Like I said mine had 7 total with 2 being on the back x-member. Maybe 5 is correct for down the frame rail. My truck was fairly stock except for a 4"lift. I'm going to use your pictures Minnz as reference for now. Thank you.
