Searching for the custom built instrument cluster
Hello I'm new to the forums here and I have been seeing this pic popping up.....all I can say is sweeeeett!!!!
I'd like to find this build for some ideas on my truck Thanks |
Re: Searching for the custom built instrument cluster
Which one?
Anthony |
Sorry this is the pic
Looks like a camaro dash. I`ve never seen that one before but maybe someone on here has.
Anthony |
That's why I'm trying to find this build....I think that Is just a standard truck instrument cluster he might have modified the original trim piece to hold it
For sure its a modified dash bezel. Could be a later model truck dash. How did you find the pic? Was there any links to a thread of some sort?
Anthony |
I would say truck cause it has a transmission temp gauge
It's a late model truck cluster in a duramax swap i remember reading the build in projects http://67-72chevytrucks.com/vboard/s...d.php?t=368734
Collector of Projects
Here's a direct swap dash that looks great.... Multiple color options. Works with stock or engine swaps
http://www.dakotadigital.com/index.c...rod/prd782.htm ![]() ![]() ![]() ![]() |
Looks like a 99-06 gauge cluster and with the 4x4 switch from it also they probably did a frame swap.Not my cup of tea but each their own.I rather run aftermarket gauges that fit the dash or get a dash panel and run whatever aftermarket gauges i want.
Thanks yall.....I really like that Dakota digital setup buy I'm doing an ls swap so I already have a donor cluster
