11-02-2015, 10:04 AM | #1 |
update on how my custom bed is turning out
heres a few pics of how my custom bed is turning out,..im usung beetle kill pine and some strips I was able to salvage from work,..had to rabbet the edges of the wood to get them to fit the strips like I wanted,..still need to pull it all apart and do a final sand then apply 5 coats of waterborne poly
looks pretty good with the tool box in there
1961 c10 longbed - gone 1964 c10 swb |
11-02-2015, 01:52 PM | #2 |
Re: update on how my custom bed is turning out
That looks real nice!
11-02-2015, 02:17 PM | #3 |
thanks,..its a lot of work,..now I see why most buy the kits premade..lol
11-02-2015, 10:20 PM | #4 |
Looks great! Looking forward to updates as I'm about to do the same. I hear you about the kits, sometimes it's worth it to save time and buy the part/kit, sometimes it's worth the extra work to save some $ and make it yourself.
11-02-2015, 10:56 PM | #5 |
Looks nice
11-02-2015, 11:06 PM | #6 |
beetle kill pine?
11-02-2015, 11:36 PM | #7 |
Yup...from colarado...the beetles kill the tree and it leaves a nice blue behind..they harvest the tree before its no good...the blueing has no affect on the wood other than color...its still a softwood...but i dont care...my truck will not haul anything heavy...more for looks and style
11-03-2015, 09:10 PM | #8 |
That looks awesome. I'm a rustic enthusiast so that's right up my alley. I even knew what wood you were talking about.
11-03-2015, 10:31 PM | #9 | |
well if it makes you feel any better, a premade kit wouldnt fit
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
11-04-2015, 06:23 AM | #10 |
May be a stupid question.....I haven't seen a bed like this so high up from the frame.....maybe its for picture taking reasons. Why is it set so high up?
11-04-2015, 07:23 AM | #11 |
The truck is built to lay frame with a big notch in the back to allow the rear end to go up much higher than normal. Raising the bed floor is needed to cover the frame work.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-04-2015, 07:27 AM | #12 |
Ahh...Thanx Jimmy.....I just had to ask. I thought there was a new trend I was missing. I still have to conquer the bed on mine so all info is appreciated!!
Looks great...... |
11-04-2015, 07:49 AM | #13 |
best use of DIN rail I've ever witnessed
NICE work |
11-04-2015, 09:52 AM | #14 |
thanks...its not din rail...its extruded aluminum used in older uhual trailers that is attached to the walls holding rubber for rub rails...i pland to countersink the bolts then run a small strip of wood in the middle hiding the bolts and giving the look of double rails...ill pollish them up to a shine
11-09-2015, 10:27 AM | #15 |
boards wetted down raising the grain,..getting ready for the las sanding before poly
11-09-2015, 10:43 AM | #16 |
11-10-2015, 12:23 AM | #17 |
That looks great!
Would love to make mine that way, thanks for the ideas. Where did you locate the beetle wood? What was that rail "intended" for...is it actual DIN rail for mounting CBs? |
11-18-2015, 02:33 PM | #18 |
some more progress, the bolts are countersunk in the rails and ive added custom inserts painted black,..looks nice and clean now
11-18-2015, 03:21 PM | #19 |
that's looking great, totally stealing the idea for black accents on the rails
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
11-18-2015, 03:27 PM | #20 | |
Alum extrusions are available in many shapes and sizes. many of them are used for rub rails and trim moulding that hides the mounting of a deck to the hull on a boat. These mouldings hold a rubber strip in them. like this: The "DIN" shape is what this extrusion actually looks very similar to but many DIN rails are pre drilled or have holes. It possible to find it with no holes. like this: More trims here: http://eagle-aluminum.com/product-ca...rail-aluminum/
My Build: 57 Chevy Pro-Street |
11-18-2015, 03:42 PM | #21 |
ya the rubber on these slides on the outside edges,..i wanted the rails to sit on the wood,,,so I tossed to rubber
11-18-2015, 04:27 PM | #22 |
That looks Awesome!
11-18-2015, 07:57 PM | #23 |
Came out nice. I like the black.
Jimmy
11-18-2015, 08:36 PM | #24 |
Looks great!!!
03-15-2016, 10:02 AM | #25 |
forgot to post finished pictures,...I still need to build a interior box for under the bed,..but that will be later on...for now its done and functional
