Old 11-02-2015, 12:21 PM   #1
dave`12
dave`12's Avatar
stupid questions choke removal
Ok, sorry ahead of time. I'm replacing my dash gadge cluster bezel. The manual choke cable won't come off at the dash.
what's the trick?
dave`12 is offline   Reply With Quote
Old 11-02-2015, 06:37 PM   #2
Redline novdog
Redline novdog's Avatar
Re: stupid questions choke removal
It won't disconnect at the dash. You have to disconnect at the carb and unscrew the bezel nut behind the dash bezel. Then you can pull it out!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 11-04-2015, 12:43 PM   #3
dave`12
dave`12's Avatar
thanx, that's what i was afraid of.
Old 11-04-2015, 12:46 PM   #4
leftybass209
leftybass209's Avatar
It's actually really easy. You're already replacing your bezel you say, so that's half the work already. Best of luck with that!!!!
leftybass209 is offline   Reply With Quote
Old 11-04-2015, 05:57 PM   #5
Mac's
I just pulled my bezel off and I did not have to remove the choke. The hole in the bezel was bigger than the knob. Maybe I was lucky?
Mac's is offline   Reply With Quote
Old 11-04-2015, 07:38 PM   #6
haysonj
haysonj's Avatar
LMC's catalog shows the knob and bezel as seperate numbers so there is either a set screw in the knob or it screws on
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 11-05-2015, 09:54 AM   #7
dave`12
dave`12's Avatar
Thanx for the replies. I took it all apart (my knob bigger than hole). Turns out the knob was threaded onto the cable.
Duh
