Door Seals
I just replaced my door seals with the "clip on" seals from classic parts of America. I'm having trouble closing the doors now and I've made several adjustments on the door side of the hinge including the door striker. The driver side will close if I slam it hard, and the passenger side will latch but then pop out on its own. Has anyone else had the same issue and if so, what did you do to fix the problem?
![]() Join Date: Oct 2009
Re: Door Seals
Ha. Welcome to the club. If you do a search on here, you'll find MANY threads of folks with the same problem. I have the same problem with GMC Pauls press on. High quality, Lonnnnng break-in. The most success I've heard folks have was with Dodge Dakota seals. Sorry, wish I had better news. One recommendation I received on here that made a LITTLE difference was to armor all the seals (every little bit helps). Another recommendation is to poke pinholes at regular intervals to allow air to escape. Haven't done that yet, but new (modern) seals are like that so it might work.
Re: Door Seals
I agree with above. There's lots of little tricks people try to get these seals to fit better, but the fact is they were never designed for these trucks. They only collapse so far before they start to give resistance, and in our case that's well before the doors are closed.
On a side note, I was waiting for my wife at the Dr office and someone parked next to me with a 67-72 truck. He closed his door softly, and with a dull thud it latched perfectly, like a new car. I immediately hopped out and asked him what door seals it had. He didn't know, but they had been replaced. There's some seals out there that work for these trucks, and that thing proved it! Now I need to find them! |
Re: Door Seals
Thanks you guys. I will try the armor all and the pin holes. GMC Paul is where I got them from. For some reason, I thought it was classic parts of America. Either way, thanks for the advice. Good luck on finding those seals.
![]() Join Date: Dec 2012
Re: Door Seals
I had great luck with the Sofseals I put on mine, but they had to be sealed with the black 3M adhesive. I just glued them a foot or so at a time and used masking tape to hold them as the adhesive set..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Re: Door Seals
After reading all the horror stories on new rubber I found a guy parting out a 93 dodge Dakota. Called and asked about the door seals and he said "come on over and I'll give em to you". Put em in my 68 truck and was still just a tad tight, so I marked where it looked tight, slipped em back off, tapped the metal they clip onto in a few spots and put em back on. Now they close like a brand new truck. Seals perfectly. The used dodge seals are broken in but still look like new.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#7 | |
Re: Door Seals
1971 C10 SWB 2WD Driver 350/TH400 2003 Silverado 2WD NBS EC-Daily Driver "Life is not easy for a boy named Sue."-Johnny Cash |
![]() Join Date: Jun 2011
Re: Door Seals
I installed the same brand and they were tight at first and after about 2 months of using the doors and leaving in the sun a few times they now work perfect and sound like Cadillac doors when shutting.Good Luck.
GARY 67 LWB CST FLEET 56 CHEV 3100 55 CHEV BEL AIR 2DR SEDAN 67 BUICK GS400 CONVERT |
Moderator
![]() Join Date: May 2007
Re: Door Seals
Used Dakota seals worked great on my 68. Gmc Paul's took a while to break in on my 72 but they work well too.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Re: Door Seals
I've got GMCpauls on mine and they're just too tight. Really have to slam. Getting a little bit better now, but it's been almost 3 months.
Has anyone noticed the "new" seals GMCpauls is listing on their website? S'posta be much better fit, but not available until Jan. 2016. |
![]() ![]() Join Date: Feb 2009
Re: Door Seals
Is it just me or does the subject come up often?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Door Seals
Seems to me the solution is to cook them in the sun just right before install.
#13 |
Re: Door Seals
Too often. The doors have been the worst part of my build. So frustrating.
#14 |
Moderator
Re: Door Seals
#15 | |
Re: Door Seals
#16 |
![]() Join Date: Apr 2011
Re: Door Seals
I had 3 sets of aftermarket one of them being the press on style tons of problems with all of them finally shelled out the cash for a set of nos ones problems solved........
