Old 11-02-2015, 08:55 PM   #1
Wildman65
65 Vent window rubber seal question
Does the vent window need to come out to replace the rubber seals. There are 2 seals. I'm guessing the straight one pulls right out but was wandering about the other one?
Wildman65 is offline   Reply With Quote
Old 11-03-2015, 01:57 PM   #2
68JOHNDEERE
Re: 65 Vent window rubber seal question
Yes you will need to remove the vent assembly to replace the seals. The lower pivot for the glass has a tension spring and retaining nut that you will need to remove, along with getting a upper pivot rivet replacement kit.
68JOHNDEERE is offline   Reply With Quote
Old 11-03-2015, 02:25 PM   #3
Lugnutz65
Lugnutz65's Avatar
Here is a popular thread showing the rebuild process. It should answer a lot of questions. Also, look at the 60-60 FAQ Index for answers to many questions about these trucks.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
