Old 09-15-2003, 02:20 PM   #1
beeroh
how to remove body trim
I would like to remove that body trim that goes all the way around the truck.
What is the best way without damaging the paint?
84 Silverado,
beeroh is offline   Reply With Quote
Old 09-15-2003, 02:36 PM   #2
Gibble
mmmm....Rye and Coke
Gibble's Avatar
Get a VERY sharp razor blade, and slowly work your way around the truck, don't pull too much on the molding or glue may take a chunk of paint with it.
After you get the molding off, a little paint thinner on a rag should help you wipe the excess glue off.
The moldings at the back corners below the taillights are screwed on, and you will have to take out your taillights to unscrew them, and then you are left with two screw holes on each back corner.
The tailgate molding is glued on in about 8 spots across the back, and should pop off with a little force, then you just need to carefully scrape off the glue and then use some thinner to wipe off the excess.
Their may be something better than paint thinner to remove the glue. Just remember, that you want to go slow if you don't want to harm your paint, and that when you remove the rear corners, you will have two small holes on either side that you would need to fill and paint...or you can leave the corners on...
Gibble is offline   Reply With Quote
Old 09-15-2003, 03:00 PM   #3
beeroh
thank you
84 Silverado,
Old 09-15-2003, 05:50 PM   #4
1FaastC10
1FaastC10's Avatar
paint thinner to remove the glue? you're dreaming! when i removed the trim from my 93, i used a piece from 3M that the snap on guy called a cheese wheel. basically a big eraser that attatches to a grinder, and just rubs the adhesive off.
1FaastC10 is offline   Reply With Quote
Old 09-15-2003, 06:11 PM   #5
Russell
Professional Grade
Russell's Avatar
I just took the good old grinder I'm repainting it all anyways, so I am not too worried about it.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-15-2003, 07:46 PM   #6
Gibble
Gibble's Avatar
Most of it should be off with the razor blade, if you're careful it comes off quite nice and barely leaves anything behind.
Old 09-15-2003, 08:28 PM   #7
Poonman86
If you have access to a heat gun(blow drier), that's the best way. No chance on gouging the paint with a razor.
Poonman86 is offline   Reply With Quote
Old 09-15-2003, 09:02 PM   #8
78SilveradoSWB
78SilveradoSWB's Avatar
WD 40 will work too, but heat method works well too.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
