Old 11-03-2015, 03:43 PM   #1
RyansToy
RyansToy's Avatar
question about Tach and number of Cyls
I read somewhere about instrument clusters, more specifically the tach (I assume) being for a 6cyl or 8 cyl? does that make sense?
Is there a difference between OE clusters for a 6 vs 8?
Wouldn't the tach signal just count cyl 1??
1968 GMC truck
910 Trim (Canadian)
127" WB
3 on the Three Trans (Saginaw SM330)
250 ci L6 Engine
HEI ignition (early 80s L6)
RyansToy is offline   Reply With Quote
Old 11-03-2015, 04:07 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: question about Tach and number of Cyls
The cluster is mostly the same. The tach itself is indeed different. That's why on aftermarket tachs there's typically a switch for 4/6/8 cylinders.
To be more specific...if a 1cyl engine is running at 500rpm that cylinder fires 500 times. If a v8 is running at 500rpm each cylinder fires about 62 times per minute. For the tach it's crucial to have it set/made for a certain number of cylinders.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 11-03-2015, 04:42 PM   #3
RyansToy
RyansToy's Avatar
I guess I had assumed it was going to read off cyl 1 only. Then it would not matter.
1968 GMC truck
910 Trim (Canadian)
127" WB
250 ci L6 Engine
Old 11-03-2015, 05:13 PM   #4
EARNHARDT#3
Yes it would. The more cylinders the motor has the less frequent they fire per RPM. It doesn't matter if it's cylinder 1,3,5,6,8. They all fire the same amount of times per minute.
Old 11-03-2015, 05:20 PM   #5
Matt Cramer
It wouldn't if it triggered off only one cylinder. But it's easier to pick up the signal at the coil terminal.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 11-04-2015, 03:24 AM   #6
swamp rat
swamp rat's Avatar
I forget what its called ( resistor???) but look at the back of the tach, there will be a little item held on by 2 nuts, there are different colors, red is one of them, i cant recall the others, if i recall correctly to change the tach from 6 to 8 or the other way all ya got to do is change out that colored part for the correct color.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
