11-03-2015, 04:53 PM | #1 |
hub studs nuts rounded cant remove
How does one remove rounded nuts from hub studs with wheel on
11-03-2015, 05:36 PM | #2 |
Re: hub studs nuts rounded cant remove
There a few ways... one way I like to try first is to hammer on a slightly smaller impact socket, then impact the nut off. If they are 3/4" nuts you could try hammering on a 18mm socket. Put some heat on them first to make it easier.
Good luck. |
11-03-2015, 05:43 PM | #3 |
I personally would take my torch and slice them very carfully with the settings down as not to do any damage to other pieces and peel it with a cold chisel. if I had a plasma cutter then I would use that. if I had neither I would use my grinder grinding the nut on both sides as close to the wheel as posible with out touching it, then use a cold chisel to peel it away from the stud. All studs will have to be replaced.. good luck. PS: try the above first...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
11-03-2015, 05:55 PM | #4 |
take your welder and tack on a 1/2 ratchet extension (better to use a harbor frieght one) to the lug nut. Use a breaker bar and tun off
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
11-03-2015, 06:01 PM | #5 |
Here is what I would try and in this order.
Go 2 Socket. Here's a link. If this will fit in there, I'd use it first. http://www.go2socket.com/ If that doesn't work or there isn't space, I'd weld on a socket or a bolt/nut and get it off that way. My dad has a welder and I am in a welding class right now so that's not hard for me to do. You may have to take it to a garage and have them do that. *A Vo. Tech center would probably do it for free as a teaching session. The air tool idea might work, I don't have any air (impact tools) so I wouldn't choose that but it might work just fine. |
11-03-2015, 06:15 PM | #6 |
Thanks for all the tips.
I'm going to print them out, for the shop. Just now we pounded on a 12 point socket on the nuts and off they came...too easy. brad |
11-03-2015, 08:26 PM | #7 |
you can also get sockets from snap on or the like to remove wheel locks when the key is lost they work great and come in a few different sizes
11-03-2015, 08:52 PM | #8 |
Here's the video. I haven't used mine yet but I bought two...
https://www.youtube.com/watch?v=iWM3Ue1ojdE |
11-04-2015, 10:36 AM | #9 |
When it got to tighten with screwdriver I thought, "couldn't that be better?". Why not make that hex head as well? Allen or torx inner would be nice. You can't always get straight on it with a screwdriver
11-05-2015, 04:54 PM | #10 |
Who Changed This?
I've also welded an old lug nut to the (in my case) McGard wheel locks to get them off, before I learned about hammering on a socket. We had a split impact socket to remove wheel locks when I worked as a mechanic. People quite surprised how easy it was to remove the locks.
