Old 11-03-2015, 05:23 PM   #1
forestb
forestb's Avatar
60-63 vent window question
I am rebuilding the vent windows on my 62 and took photos to document. My problem is where the spring is bolted on to the bottom pivot rod. Both my widows have different washers in different places. I even have a spare vent window assembly and that is different also. Does anyone have a photo of what parts go in what order on a 60-63. Is it the same as the 64-66?
forestb is offline   Reply With Quote
Old 11-03-2015, 11:53 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 60-63 vent window question
You might find what you need in the following thread:
http://67-72chevytrucks.com/vboard/s...ht=vent+window
I looked through the 1960 shop manual and didn't find any photos worth sharing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-04-2015, 01:02 PM   #3
forestb
forestb's Avatar
Thank but I have already seen that thread. I just wish I new if the 62's had the same order of washers as the 64-66. I guess I can check to see if one of my 3 vent windows has the same line up as the one in the thread. I think only one of them has the washer with the flat end.
Old 11-05-2015, 12:06 PM   #4
BenkeBird
BenkeBird's Avatar
I donīt know if this will help you but itīs from my -62 Panel when I change the rubber and frame.
BenkeBird is offline   Reply With Quote
Old 11-05-2015, 12:41 PM   #5
forestb
forestb's Avatar
Yes thanks it does. That looks like the same order as the 64-66 has in the other thread.
Old 11-07-2015, 03:15 PM   #6
NHollywoodCody
Smile Re: 60-63 vent window question
forestb I'm in North Hollywood and Need that metal pivot for the vent lock. You mentioned you have 3 vent window set ups, would you be willing to sell me that piece if you have it? Thanks
NHollywoodCody is offline   Reply With Quote
