Old 11-03-2015, 11:40 PM   #1
53Sparky
53Sparky's Avatar
Upper Control Arm Shaft orientation Theory
I'm in the middle of a crossmember swap on my '62 C10. I have the both the original upper control arm shafts and Moog K6184 positive camber problem solver upper control arm shafts in my shop. Both sets have a flat profile on the outside surface and a curved profile on the side where the shaft touches the frame(where you would put shims in to adjust the alignment).
Does anybody know what the purpose of the curved profile on the shim side is? Why they would do that instead of having 2 flat surfaces on both sides?
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 11-04-2015, 07:49 AM   #2
PGSigns
PGSigns's Avatar
Re: Upper Control Arm Shaft orientation Theory
The curve fits the curved washer that is the piece that goes up against the shaft. This allows the shaft to have full contact on the washer behind it as you change the angle of the shaft during alignment allowing you to pull it up tight. If it were flat it would only touch in one small spot.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-04-2015, 09:26 AM   #3
53Sparky
53Sparky's Avatar
Ah. I was not aware of the curved washer. My donor crossmember came in pieces and did not include shims or those washers. Any ideas if the washers are readily available at a parts store or alignment shop? Obviously there's a ton of them in the local pick n pull.
Numbers 6:24-26
Old 11-04-2015, 02:00 PM   #4
SCOTI
SCOTI's Avatar
I doubt the local parts house would have them. LMC does as well as the local Pick & Pull.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-04-2015, 09:43 PM   #5
53Sparky
53Sparky's Avatar
Thanks, SCOTI, I got some at the Pick & Pull today. 15 minutes and $2 entry fee.
Numbers 6:24-26
