Old 11-04-2015, 11:32 AM   #1
BigSix
30 ohms on the sending unit for 65?
Sorry if this question is silly - on eBay there are GM sending units for 64 and older that are 0-30 ohms but the same company has 65+ as 0-90 ohms? I think my 65 is still a 0-30 ohms...any input?
BigSix is offline   Reply With Quote
Old 11-04-2015, 01:53 PM   #2
61K10
61K10's Avatar
Re: 30 ohms on the sending unit for 65?
should be 0-30 somebody else will chime in. I bought a new cheap one $29, and it didn't go to full, only about 3/4. Have seen them for $49 don't know if there is any difference. put my old one back in and it works fine.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-04-2015, 02:17 PM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I got my sending unit from Truck and Car shop and it worked fine. Worked so fine that when I went over bumps the gas that caused the sending unit to move up and down moved the gauge with it. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-04-2015, 02:33 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
Yes, if you still have the factory gas tank behind the seat and the original fuel level gauge, you will need the 0-30 ohm sending unit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-04-2015, 03:15 PM   #5
Slow Build
Slow Build's Avatar
Wouldn't you need a 0-30 ohm unit no matter what tank you have (in-cab, rear frame mount,...) as long as your using the stock gauge?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-04-2015, 03:46 PM   #6
morethanstock66
morethanstock66's Avatar
The big thing is to match the sending unit with your gauge. If you have OEM gauges for your model, it should be 0-30ohm. Aftermarket can be 0-30ohm, 0-90ohm,204-33ohm, ect.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 11-04-2015, 04:21 PM   #7
BigSix
Awesome - thanks guys. I have the stock gauge but I need to shorten the rod on the stock sending unit because its being installed in a 1996 Cadillac Fleetwood tank. Basically installs like the 69 Camaro tanks in the back, and fills under the tag, but is poly so it works with my diesel and no risk of rust in the fuel system. Right now its just mocked up with some ratchet straps until I get the wiring and suction/return setup.
Old 11-04-2015, 06:36 PM   #8
vin63
vin63's Avatar
This is what I was referring to. If you are using a different tank application, it would be better to use the sending unit for that tank, and use a resistor conversion, or use a marine type adjustable universal sending unit that matches the sending unit/fuel pump assembly opening for that Cadillac tank. Be careful modifying the sending unit for the OE truck gas tank.
Old 11-04-2015, 10:13 PM   #9
BigSix
I've been real careful with that sending unit - I won't move it around too harsh.
