11-04-2015, 02:05 PM | #1 |
Big disc swap from factory disc.
Hey guys,
been searching high/low for a 13" front disc conversion for my C-10 It already has factory 5 lug disc, just want something bigger since I now have 18" rims. Thanks |
11-04-2015, 02:14 PM | #2 |
Re: Big disc swap from factory disc.
Check with board supporting vendor Travis @ Pro Performance
http://67-72chevytrucks.com/vboard/s...d.php?t=600417 Or, board supporting vendor Boris/way2lo2 http://67-72chevytrucks.com/vboard/s...d.php?t=465140
11-04-2015, 03:23 PM | #3 |
Thank you Sir.
11-04-2015, 08:53 PM | #4 |
i'm going to tailgate off this thread since it's hanging out there...
i've been researching big brake upgrades for the suburban's and i'm curious to the performance and daily benefits to a 13"/14" Baer or Wilwood system over a more basic 12-13" system with factory calipers and parts for these heavy ass trucks anybody have any thoughts |
11-04-2015, 09:32 PM | #5 | |
11-05-2015, 11:43 AM | #6 |
Never Ending Projects
Well not exactly. The contact area is dictated by the pads. What larger rotors have is more surface area to dissipate heat and more important, leverage. The downside is in most cases you increase unsprung weight, which can effect ride quality.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-05-2015, 12:04 PM | #7 |
I summarized. Thanks for clarifying the specifics for those that might not know that info.
