AVS C-Notch Anyone using or have pics?
Wondering if anyone is running this set-up? Didn't seem bad for 150? Looks like you can put it over the frame, weld it in, then cut your old frame piece off and weld in the underside.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
Re: AVS C-Notch Anyone using or have pics?
I installed one from avs but it wasnt 67-72 specific. It looks the same tough. And you are right, you mount it on your frame, weld it in and cut the middle off. I beleive its 3/16's thick.
How did you like it? It looks pretty good to me?
It was pretty good. I think most companies sell them in 3/16's thick. Just make sure you weld some sort of crossmember at the top, since you have to cut out the stock crossmember. I just used two sticks of 1 1/4" round pipe and welded them inside the top corners
Installing it was pretty straightforward and quick too
