Old 11-04-2015, 03:29 PM   #1
leftybass209
leftybass209's Avatar
Felpro 1 piece pan gasket install with engine in place!
I hate leaks!!!!! I decided I needed to do something about the 4 piece pan gasket, which I narrowed down to leaking from the passenger side dipstick area, and the rear lip.
I decided I didn't want or need to pull the engine, or raise it up at all. I'm using pan rails, so there wasn't any distortion around the pan bolt holes. I purchased a Felpro OS34510T, the kind that comes with the bolts.
The lip was cleaned with acetone, and the gasket was flexible enough to slide under the pan and around the outside of it, it dropped in place with just a dab of RTV at the front and rear joints. After I sealed it back up, I took the truck for a few long drives.
It's been a week and there are no leaks from the pan gasket at all!
leftybass209 is offline   Reply With Quote
Old 11-04-2015, 03:42 PM   #2
tdangle
tdangle's Avatar
Re: Felpro 1 piece pan gasket install with engine in place!
I wondered if this was possible. Great news, it is!! I know what my next project is.
Thank you.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-04-2015, 05:49 PM   #3
7tee
7tee's Avatar
Congrats, they're good, used on my vette and I'm pleased also...
7tee is offline   Reply With Quote
Old 11-04-2015, 06:22 PM   #4
Steve Cole
You did this on a first generation 350?
Steve Cole is offline   Reply With Quote
Old 11-04-2015, 06:25 PM   #5
leftybass209
Yes sir, it's a 350/290 crate utilizing the front motor mount position.
