09-15-2003, 03:42 PM | #1 |
4X4 to 2X4 question.....
I know it has been covered a bunch on here but what is involved in swapping a 4X4 to a 2X4. I just scored a K-5 4X4 and I want to build a 2 wheel drive Blazer. I know some of you guys have done it. Please Help!
Thanks BBB |
09-16-2003, 10:07 AM | #2 |
Post Whore
PM member blazerboy as he has done it. He isn't on the board too much so he may not see your post.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-16-2003, 01:46 PM | #3 |
yeah , its a pretty easy swap to do . it's better to have a donor truck to swap all stuff off of . that way you get all the little brackets and bolts that you will need . i used stuff off of a later model(74) 1/2 ton truck . i swapped it all into my 69 blazer. once you get to looking at all of your bolt holes you will see that alot of them line up! i think i only had to drill a couple holes for some other bolts . and all you do on the rearend is find a leafsprung 5 lug rear to trade for your six lug rear . its really pretty easy to do and once you tear into it , all of the small kinks in the details will smooth themselves out. i am at work so i can't go into detail but email me and i will give you the complete breakdown on it
