Old 11-04-2015, 07:34 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Speedometer/Odometer took a dump...
I was driving along and all of a sudden I noticed my speedometer needle bouncing back and forth between 30/70mph non stop. The bouncing back and forth gets worse with greater speeds.
The odometer had rolled over a couple years ago and showed around 6,000 miles. It completely rolled back to zero and stopped working...
Never seen anything like that before.
Any guesses as to what broke before I get the dash out (probably be a couple/few weeks).
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-04-2015, 08:03 PM   #2
wreckedchevy
wreckedchevy's Avatar
Re: Speedometer/Odometer took a dump...
i'm on my 4th one this year the one started going so crazy it broke the needle off.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 11-04-2015, 08:15 PM   #3
67ChevyRedneck
4th???
New aftermarket ones or old used OEM ones???
Mine was the original.
Jesse James
Project "On a Dime"
Old 11-04-2015, 08:20 PM   #4
tdangle
tdangle's Avatar
Until I got to the part about the odometer rolling back to zero, I was going to suggest the cable. I had a cable wear at a bend and as it was unwinding the strands the speedo was going crazy.
My guess is the speedo itself is broke. Good Luck
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-04-2015, 08:38 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
If you haven't already you need to remove the speedo cable assembly, pull the cable out of the sheath, wash the cable with solvent and flush the sheath out with solvent, PB Blaster, or Liquid Wrench, then blow it out with an air hose. Lube the cable with some light oil and put it back together. What you are describing is caused by the cable binding in the sheath. Sometimes it will cause the cable to twist inside the sheath ruining the cable.
LockDoc
Leon
Old 11-04-2015, 08:51 PM   #6
67ChevyRedneck
The cable is brand new, well maybe 6 months old.
I know the cable not being lubed can cause the bouncing, but why did my odometer roll back to zero and quit working?
Jesse James
Project "On a Dime"
Old 11-04-2015, 08:59 PM   #7
Redline novdog
Redline novdog's Avatar
the cable is the bouncing.even if new needs lube! the odometer is kind of seperate plastic gears that can shear if the speedo cable is whipping as stated. Sounds like a speedo rebuild!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 11-04-2015, 09:07 PM   #8
67ChevyRedneck
Well crap.
I used this from O'Reilly. Maybe I didn't put enough.
http://www.oreillyauto.com/site/c/de...eter+lubricant
Jesse James
Project "On a Dime"
Old 11-04-2015, 09:32 PM   #9
toolboxchev
Could be that silly little box on the transmission, I took mine apart and re-greased it after a good cleaning.
toolboxchev is offline   Reply With Quote
Old 11-04-2015, 09:34 PM   #10
67ChevyRedneck
I just redid that too, I put a new gear (same P/N as old gear) and new seal in it, trans is a 700R. The trans fluid lubes that.
Jesse James
Project "On a Dime"
Old 11-04-2015, 09:51 PM   #11
swamp rat
swamp rat's Avatar
Mine was bouncing and i lubed it, the bouncing stopped.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-05-2015, 02:32 AM   #12
wreckedchevy
Originally Posted by 67ChevyRedneck View Post
4th???
buddy of mine has piles of them so I just keep grabbing one from him. I did replace the cable as well because I thought it was the source of my original making a lot of racket but it wasn't. the last one (still in my truck) was working great went about 60 miles and did a big old burnout in a parking lot and it went to heck screaming like a banshee had to pull over and unhook it.
