Old 11-05-2015, 12:21 PM   #1
Mr Big
original 3 speed or sm420?
My 66 3/4 is down due to a sudden onset of tranny noise. I have yet to pull the original 3sp so we're not sure yet what will be involved to repair it.
Bought this truck from the original owner who kept very detailed maintenance records and the truck is currently completely original, so I'd like to stay with a factory available configuration if we convert.
Was thinking of trying to source an original sm420, shifter, and floor hump to convert to 4sp? Will these parts be difficult to find?
Thanks for the advice/help. Glen in TN.
Mr Big is offline   Reply With Quote
Old 11-05-2015, 12:38 PM   #2
XLCOR_65
XLCOR_65's Avatar
Re: original 3 speed or sm420?
I recently converted from the 3 speed to the SM420 and seriously cannot stop grinning as I drive it now. I love the compound gear and also the particular whine it makes. It just feels a lot tougher and more purpose built, in my opinion.
For a quick down and dirty swap, you'll obviously need the trans and high hump, of course, but you'll also need the beefier drive shaft and heavy duty carrier bearing (CaptainFab makes the mount you'll need). I also swapped the columns since I didn't need the 3-speed column anymore, but that isn't completely necessary...you could just get by with removing the shifter and linkages.
Hope this helps. Good luck on whichever you decide!
1965 C10 LWB SBW, 292, SM420
1963 Chevy II SS
1951 Chevy Business Coupe Gasser
1949 Willys Overland
XLCOR_65 is offline   Reply With Quote
Old 11-05-2015, 12:43 PM   #3
Brad54
Brad54's Avatar
If your truck is completely original, you'll need to be aware that swapping to the high hump trans tunnel isn't a bolt-in.
Where the tunnel bolts to the firewall, that flange is spot-welded to the base of the firewall. They use a different flange between high and low hump, so you'll need to break the paint and undercoating to make the conversion.
Just one more thing to keep in mind.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-05-2015, 01:03 PM   #4
Mr Big
Good info...a 4sp parts truck would be the best situation.
Old 11-05-2015, 01:07 PM   #5
Mr Big
-Brad
Would graft/weld in the center floor cab section from a parts truck work, of could I get away with something less? I'm wondering where the floor contour changes from low hump to high. Glen
Old 11-05-2015, 02:05 PM   #6
scuderia
scuderia's Avatar
Pretty straight forward.. simply cut out the original hump leaving a good 1-1/2" of flange for the new one to lay over.
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 11-05-2015, 09:05 PM   #7
Mr Big
Thanks for the good/helpful info. Now to find the parts. Glen
Old 11-05-2015, 10:21 PM   #8
scuderia
scuderia's Avatar
I've got a decent high hump but I don't have the firewall piece.. If interested let me know.
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 11-05-2015, 11:42 PM   #9
Mr Big
Thanks for offering, let me see what I can dig up.
Maybe the whole deal at one spot. Glen
Old 12-29-2015, 12:52 AM   #10
Isaiah92260
Isaiah92260's Avatar
I would like to bring back this Thread, I've found a really good SM420 for much truck that was pulled out of a running 66, I have original 3 speed too that's tired that I really want to get rid of before I throw in my 283 I still have waiting. My main question is.....
What's the length someone like us need for a Driveshaft? I know that drive shafts for the SM420 60-66 long bed would need to be than the 3 speed would be...
Isaiah92260 is offline   Reply With Quote
