Old 11-05-2015, 11:49 PM   #1
warriorsimi
how low on rallys?
here's my 72 with rallies my question is how low can I go with out it hitting the rim on the inside? it rubs right now ,I trimmed the lower control arm already it helped a bit but not much.i ordered two inch drop springs and it made it worse I have 3 inch drop spindles with the 15" rallies is the only answer is to get bigger rims? this pic is before installing the drop springs.
warriorsimi is offline   Reply With Quote
Old 11-06-2015, 07:52 AM   #2
jondancer
Re: how low on rallys?
Get the 6" rally wheel from a van and use them up front . I had a 5.5" drop in the front with no rubbing.
jondancer is offline   Reply With Quote
Old 11-06-2015, 08:32 AM   #3
scotts72
scotts72's Avatar
I ran into the same situation when I was lowering mine, I was running 15" Rallys and just last month went to 20" American Racing Rallys. I don't think you would have to go to 20" but that is what I did to clear the control arms and the inner wheel rims. The first picture is old rims and bottom is the new ones.
scotts72 is offline   Reply With Quote
Old 11-06-2015, 08:37 AM   #4
jondancer
I REALLY like those 20's!
Old 11-06-2015, 08:48 AM   #5
SoCoC10
SoCoC10's Avatar
I'll trade you a pair of 6"-7" wide Rallys for two of your wheels.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 11-06-2015, 11:01 AM   #6
Willie Makeit
Willie Makeit's Avatar
my 67 is on bags and I'm running 6.5" rallies in the front with ECE spindles. full dump and no rub.
Willie Makeit is offline   Reply With Quote
Old 11-06-2015, 11:16 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Corvette Rallys, but same problem... went to 7" wheel in front.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-06-2015, 11:19 AM   #8
scotts72
scotts72's Avatar
Looks exactly like mine did. FYI good looking shop truck!
Old 11-06-2015, 12:11 PM   #9
warriorsimi
I am looking into a set of 20's right now but will the stock steel rims fit ? They should be alot skinnier.i love the look of my rallies but I also plan on airbags.
Old 11-06-2015, 12:19 PM   #10
warriorsimi
Thanks Willie I'll try that
Old 11-06-2015, 10:20 PM   #11
volksworld
does the control arm to 8 in ralley clearance issue only happen with drop spindles?
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 11-06-2015, 10:33 PM   #12
CarterD2015
CarterD2015's Avatar
I'm no expert by any means but wheel to a arm distance is determined by wheel width and the amount of drop built into the drop spindle. The more drop built into the spindle the closer the rim will come to the a arm.
Dennis
37 ford coupe
68 short narrow
72 short wide
CarterD2015 is offline   Reply With Quote
Old 11-06-2015, 10:39 PM   #13
warriorsimi
I would say yes cause when I installed the lowered springs it got worse.it rubbed a bit with the drop spindles but when I installed the drop springs it got worse..
Old 11-06-2015, 10:48 PM   #14
CarterD2015
My truck is sitting on rallys now with 2 in drop spindles and air ride. I have about 1/4 in of clearance with the suspension as low as it will go. I've never checked to clearance with the suspension at ride height. It may change I don't know. I would cycle it through its range of motion and measure for you but my truck is 70 miles away right now.
Dennis
37 ford coupe
68 short narrow
72 short wide
Old 11-06-2015, 11:17 PM   #15
warriorsimi
I think if I'd I had 2 to 21/2 drop spindles it would be ok but with 3 inch it's too much.
Old 11-07-2015, 10:57 AM   #16
67ChevyRedneck
My pic above is with 2.5" spindles and 8" rallies. I almost think a 2" spindle would be OK with 8" wheels, or at least only a little shaving.
Jesse James
Project "On a Dime"
Old 11-07-2015, 11:05 AM   #17
Malamute
Malamute's Avatar
I have 2.5" DS and no rubbing. I honestly don't know my wheel width or BS. They are at least 7" though.
Malamute is offline   Reply With Quote
