Old 11-06-2015, 07:38 AM   #1
jasnake65
Hood Alignment sideways and door alignment
Going to look at a truck(1960) and he sent me these picks showing the hood needs to be aligned still, whats the best way for side way movement. Then the doors need to be aligned also. If I do purchase the truck what is the best way to tackle this
jasnake65 is offline   Reply With Quote
Old 11-06-2015, 09:15 AM   #2
Dans1960SWB
Re: Hood Alignment sideways and door alignment
I'm not sure but if you find let me know. My 60 looks the same exact way..
Dans1960SWB is offline   Reply With Quote
Old 11-06-2015, 11:16 AM   #3
1963c-10
1963c-10's Avatar
The hood alignment comes from the hinges in the back and the hood latch on the front. Doors are done of the hinges and striker plates. The hood alignment may also be to the front end not being square if its been removed and reinstalled.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-06-2015, 11:39 AM   #4
jasnake65
Any best way to check the front end to make sure it's square? Have access to a hoist when I'm looking at it
Old 11-06-2015, 02:39 PM   #5
1963c-10
1963c-10's Avatar
Take measurements from the firewall....inner corner of the top of the inner fender to the radiator support. Need driver side firewall inner fender to pass side radiator support and pass side inner fender to driver side of the radiator support. Numbers should be the same or the font end is not square. If one side is longer, then the front end needs loosened and readjusted.
Front end should assemble as inner fenders/core support 1st. Outer fenders/grill support 2nd.
It is easier to adjust the doors with the front fenders off....gives much more room to access the hinges.
Factory chart for door gaps attached.
Old 11-06-2015, 06:58 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Here are the factory instructions related to aligning the hood hinges:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-07-2015, 04:25 PM   #7
jasnake65
Is there a place I can buy that book? Ended up buying the truck.
Old 11-09-2015, 10:43 AM   #8
1963c-10
1963c-10's Avatar
Its the factory shop manual. Can get from most vendors, ebay, etc
Old 11-10-2015, 02:45 AM   #9
61ChevyPanel
Active Member
61ChevyPanel's Avatar
The rear of my '61 hood sits high like yours too. I've seen other '60 & '61 where the rear reinforcement assembly of the hood separates from the hood sheet metal. The gap of the left side of my hood and the reinforcement is well over an inch. I use my hand to push down the hood corners after I've closed the hood. If you can do that, I wouldn't suggest moving the hood until the problem is fixed. I'm not a sheet metal expert; does anyone else have experience fixing a rear reinforcement assembly hood separation?
61ChevyPanel is offline   Reply With Quote
