Old 11-07-2015, 03:03 AM   #1
truckkeepsmesane
truckkeepsmesane's Avatar
Betty
I am in the process of rebuilding a 67 C20 into a K20. Will be posting pictures soon. Got all the glass out tonight, dash pad is off, started breaking down the steering column. Pulled the fan and the alternator. She's moving forward
67 C20 to K20 Conversion
283 SM465
See my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=687765
truckkeepsmesane is offline   Reply With Quote
Old 11-07-2015, 10:00 AM   #2
truckkeepsmesane
Re: Betty
This is Betty before I started disassembly. I picked the name due to my job in aviation and b!tc#ing Betty is the voice on the aircraft that warns you of mishaps. I didn't realize that so many people chose the same name.
283 SM465
Old 11-07-2015, 10:06 AM   #3
truckkeepsmesane
Re: Betty
First day of disassembly. Front clip removed, inner and outer fenders, seat, steering wheel, and gas tank
283 SM465
Old 11-07-2015, 10:52 AM   #4
cooperhw
cooperhw's Avatar
Re: Betty
Very nice build thread you got going there. I also have a Betty cept mine is called "Ugly Betty". Nova drag car.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 11-07-2015, 01:58 PM   #5
truckkeepsmesane
Re: Betty
Dissy continues. Took off the fan and alternator, started working on the heater and got distracted. Ended up taking apart the dash and the glass, did a little grinding on the cab.
283 SM465
Old 11-08-2015, 05:35 PM   #6
truckkeepsmesane
Re: Betty
Finished the cab dissy today. Only thing left is the high hump and a lot of rust busting, and of course, new parts.
283 SM465
Old 11-08-2015, 05:53 PM   #7
mooseknuckles
mooseknuckles's Avatar
Re: Betty
nice start!
mooseknuckles is offline   Reply With Quote
Old 11-12-2015, 05:58 PM   #8
truckkeepsmesane
Re: Betty
Thanks for the encouragement. I can't post the video but my son was helping me take the tailgate off yesterday and it was "amazin!" and "really super awesome".
Quick question: I picked up a NP261 transfer case from a guy at work and I am wondering if any advice can be offered on how it my work with the SM465. I would appreciate it. Thanks in advance
283 SM465
Old 11-22-2015, 01:31 PM   #9
truckkeepsmesane
Re: Betty
Disassembly continues. Got the bed sides and front panel off, cab is off the frame, laying on the bed floor so I could inspect all the cancer on the floor boards and cab mounts. Finding some parts here and there collecting for the final build.
283 SM465
Old 01-11-2016, 02:58 AM   #10
truckkeepsmesane
Re: Betty
After a long break I continue disassembly. Built myself a little cab stand on wheels with some scrap lumber I had laying around. Got the engine out, which ended up being more of an adventure than I bargained for, but it's out. PO decided the cure for rusted out bed bolts was to seam weld the bed to the frame mounts. Still working that. Progress is slow but continues.
283 SM465
Old 01-11-2016, 02:59 AM   #11
truckkeepsmesane
Re: Betty
who needs bolts?
283 SM465
Old 01-11-2016, 10:38 AM   #12
dfwright
dfwright's Avatar
Re: Betty
Good Grief! You have my sympathies on this... Sometimes you just have to scratch your head and wonder what they could possibly have been thinking... just wow.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-07-2016, 03:18 AM   #13
El Dorado Jim
Re: Betty
I would get a married sm465/205 tcase out of any 70's truck and use that, That is what I have in my '72 and '74 K20's
El Dorado Jim is offline   Reply With Quote
Old 02-08-2016, 10:20 PM   #14
swamp rat
swamp rat's Avatar
Re: Betty
Cool truck! Not so cool welds on the bed... I want to try and keep track of this build! Good luck.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-22-2016, 08:50 AM   #15
truckkeepsmesane
Re: Betty
So life has gotten a bit busy so I haven't been on in a while. I have the bed floor off, picked up some axles off my neighbor with matched 3.73 gears, half ton axle shafts though, so I'll be swapping those out for the 8 lug 3/4 ton axles and hubs. Decided to put in a 350 to replace the 283 to help move the truck. Scrounging parts, found a married SM465/NP205 combo that I should be picking up in a couple of weeks. Cut the flange out of the frame and currently welding up the patches in the front. Pictures are coming.
Also picked up a spare roof thanks to a buddy, saving $$$ and stock piling parts to rebuild the cab and bed sides. My garage looks like the truck exploded I have so much stored but at least the wife is okay with it! Thanks for the encouragement fellas!
283 SM465
Old 04-23-2016, 12:55 AM   #16
El Dorado Jim
Re: Betty
want to see more pics!!
Old 05-21-2016, 03:17 PM   #17
truckkeepsmesane
Re: Betty
After a long pause, I managed to finally get the right side of the frame mod done. Need to finish the left side and then strip the axles off.
283 SM465
Old 08-22-2016, 08:22 PM   #18
Crank
Crank's Avatar
Re: Betty
Any updates Matt?
Crank is offline   Reply With Quote
