Old 11-07-2015, 11:18 AM   #1
rossboss
rossboss's Avatar
energy suspention front spring grommets?
Bought a set of 3.2112g front spring replacement grommets. I'm having a problem with the placement of the rear front spring grommets in the kit. Four of them have a wider shoulder than the other four. How are they placed, seems like they should all be the same.
rossboss is offline   Reply With Quote
Old 11-07-2015, 07:07 PM   #2
tjsblazer
tjsblazer's Avatar
Re: energy suspention front spring grommets?
No. They need to be different thicknesses because the width of the spring is narrower than the frame brkt for the shackle.
Narrow in the frame. Wider ones in the spring eye.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 05-10-2016, 10:49 AM   #3
calgood
Sorry to revive such an old thread, but I purchased the same kit and it appears the shoulder on the bushings tha go in the spring eye are far too large to fit in the frame shackle once assembled.
I was thinking about taking some thickness off of them, but wanted to see what others have done. Am I supposed to just press it into the frame?
calgood is offline   Reply With Quote
