Anyone bolt their outer grill to the grill brackets?
I had to drill out the rivets holding the outer grill to the grill brackets. The grill brackets were just too rusty and one was really trashed.
Now I probably could re-revit it back together but I'd rather bolt it. I asked this question before and was directed to buy these bolts but I am not sure how they'd ever tighten up, as the bolt head has no slot for a screwdriver. I'd like to use a pan headed bolt with a slot, short, yet wide enough to take up the hole. Anyway, what did others do? Pics would be nice. I would like to reassemble my grill this month. Thanks! |
#2 | |
![]() Join Date: May 2010
Re: Anyone bolt their outer grill to the grill brackets?
Since I've recommended them on several threads, I recently took a picture of them installed. |
Well buddy, I really want to thank your for your persistence. I have not tried these and I bought just what you linked in that older thread.
I will give them a shot and thanks for both trying to help me again (in the face of my doubts) and for showing a pic. The pic looks great. I should get the grill back this month. I should have everything ready to go for reassembly by then. I'll try and get pics. |
But I have a question, what keeps the heads from turning and not allowing it to tighten up?
Try them. You'll like them.
Serrations/teeth/grips in the mating surface of the head. As the nut snugs up they bite in. It's not like you are torquing them.
![]() Join Date: Oct 2015
Where can I get these rivet screws?
Pick the size you want. I think mine are the 1st ones linked below. The smaller 8-32 head size may be closer to the original rivets.
http://www.ebay.com/itm/25-pcs-10-32...zuruekrmzEAHaw http://www.ebay.com/itm/10-32-x-5-8-...MAAMXQuTNTM0ej http://www.ebay.com/itm/8-32-x-5-8-C...4AAOSw-nZTp0UD |
#9 | |
I just put what I have into the grill bracket (outer grill still at the polisher) and it tightened up by hand and the bolt did not spin! So, it looks like my fears were unfounded. ![]() Last edited by In The Ten Ring; 11-07-2015 at 11:06 PM. |
I know this is a bit old, but maybe for someone else, I used nut rivets as well, but used stainless button head screw.
I also used them with socket cap screws on both my shifter rings. ---
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
Often, when you're lucky, you can snug up a nut finger tight and finish off tightening with a wrench without ever touching the nut. Especially when using lock washers. Removing is another story. But with these screw-in rivets, you get them snug and the grips on the washer are all it takes to bind enough so it doesn't turn "as it gets tighter and tighter" using the wrench
![]() Join Date: Feb 2009
Very cool. I may give these a shot.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#13 |
![]() Join Date: Apr 2005
Looks like a good idea!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#14 |
I have used those smooth head rivets on a lot of grills from the 50's car grill to a 68 Chevy truck grill, they work great
#15 |
Those are just what I have been looking for.
'69 swb stepside in progress. '59 Corvette lifetime project |
#16 |
