Pulleys 327 vs 292
Collecting parts for my 327 that will ultimately replace my tired 292. I believe that I can reuse the starter, alternator and a few other bits. I'm wondering about the pulleys for the water pump and crank? Are they the same? The 327 comes from a '68 Camaro and I'll be using short water pump if that makes any difference. Oh, and what about the fan, can I use the one from the 292? I already have the V8 size radiator... thanks
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota Last edited by scuderia; 11-07-2015 at 01:58 PM. |
Re: Pulleys 327 vs 292
Here's what I have.
Short WP. Might have to press the mounting hub up or down to get proper alignment. Water pump pulley is GM 3905995 Crank pulleys are 3744043 double & 3751232 single for power steering. PS bracket . 3941114 will need to cut a little with a 8''Bal. |
#3 | |
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
