11-08-2015, 12:33 PM | #1 |
M A P 2003 Tahoe 5.3
I am in need of a new M A P sensor is there one better than the other
I lookedthem up and they range from 5.00 to 120.00 with the same part number I am thinking somewhere around 50.00 and A C Delco the part number on my M A P is 09359409 Is there a better one out there or is the "less expensive" one any good?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-08-2015, 07:36 PM | #2 |
Old member
Re: M A P 2003 Tahoe 5.3
I have a old S-10 MAP and was wondering the same thing. It looks just like the one on my 6.0!
11-08-2015, 08:03 PM | #3 |
meowMEOWmeowMEOW
Delco/Delphi is the way to go.
BTW, you can get a TMAP from a j-body and some of the older 3800 cars as well and it will swap direct. The MAP scale and functions are the same, but it has an additional temp input that can be used for IAT2 or in lieu of the temp sensor in the MAF.
11-08-2015, 09:04 PM | #4 | |
