Old 11-08-2015, 04:17 PM   #1
Houston Ben
Houston Ben's Avatar
Do I need new Axle shafts? (Pic inside)
Hey all,
I thought I had chased this wobble down with the front spindle but now I believe it is coming from my rear axle. The driver side rear axle had a small amount of play in it where I could kind of rotate it in a circle and up and down a very tiny bit. The passenger side did not do this but I pulled both as well. Does this look like I need new shafts or just bearings?
Driver side
Pass side
Thanks for any help.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 11-08-2015, 06:58 PM   #2
chrismoore701
chrismoore701's Avatar
Re: Do I need new Axle shafts? (Pic inside)
I would check the play in the bearing and then the play between the bearing and the shaft. If no play at the shaft. Your good
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 11-08-2015, 07:04 PM   #3
bmchevy1979
bmchevy1979's Avatar
I would replace the passenger side for sure but if your buying new I would just get both less to worry about. Makes me wonder about the 12bolt in my k5 now
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 11-08-2015, 09:44 PM   #4
Jake Wade
Jake Wade's Avatar
Pass side bad for sure.
Jake Wade is offline   Reply With Quote
Old 11-08-2015, 10:24 PM   #5
nonstop
Both of them look bad. Repair bearings have already been used. The passenger side is the worst, but the driver's side looks like it is getting a lip as well and will need eventual replacement.
nonstop is offline   Reply With Quote
Old 11-08-2015, 11:08 PM   #6
Blown06
Blown06's Avatar
Passenger side axle and bearing for sure, if it were me I would go ahead and do both sides. You're probably looking at a couple hundred bucks to get new axles, bearings and seals. If money and time is a factor, polish up the passenger shaft (you'll likely never be able to remove all of the pitting, but you can make it smoother) stick it all back together until you can round up the parts. Then get it knocked out.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 11-08-2015, 11:12 PM   #7
Houston Ben
Thanks for all the replies, much appreciated!! I ordered Moser axle shafts, studs, and seals. I was going to order the timkin bearings but a review on there said they were repair bearings and not what was stated so I will be buying bearings local. I will let you know how it turns out, hopefully this is the source of the wobble.
Ben
