Old 11-08-2015, 09:24 PM   #1
ramses69
67 c-20 rear end 5 lug conversion
What is the best year 5 lug rear end to replace the one i have on my c-20?
ramses69 is offline   Reply With Quote
Old 11-08-2015, 11:17 PM   #2
graymond1967
graymond1967's Avatar
Re: 67 c-20 rear end 5 lug conversion
I would change the axles and brake drums. Probably the cheapest. Unless the rear end is toast.
ray
1967 Chev C10, in the family since 1967, iron head 502, turbo 350, white with red, unrestored.
1970 Acadian SS350, 350 with muncie 4 speed, 12 bolt, best time 13.414 @ 103.72
graymond1967 is offline   Reply With Quote
Old 11-09-2015, 12:04 AM   #3
ramses69
Thank you for the reply. Sorry for the noob questions. What axles should i replace them with? Is there a quide on how to do that?
Old 11-09-2015, 11:42 AM   #4
Redline novdog
Redline novdog's Avatar
If your truck is a c/20 it should have an 8lug front and rear wheels. to change to 5 lug. everything will have to be off of a 1/2 ton with 5lug running gear.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 11-09-2015, 02:14 PM   #5
graymond1967
http://www.speedwaymotors.com/1970-C...Kit,46220.html
Here is one conversion kit for your truck.
You would need to do the front to go to five lug as well, I am assuming you have drums,
http://www.speedwaymotors.com/1967-1...Kit,46357.html
You might have to change the spindles on the front but this may be a good opportunity to go with dropped spindles. I "think" that the front suspension from a newer truck may work on yours. 73-87.
These are a guideline, you may wish to crank up your search engine and find other conversions. Car 5 lugs are different than truck five lugs.
Cheers.
ray
Old 11-09-2015, 04:12 PM   #6
Redline novdog
How many lugs are on your wheels??? Pictures please if you want some help!!
Old 11-09-2015, 09:44 PM   #7
Elliot949
Elliot949's Avatar
Cheers.
ray
The Rear conversion you are showing from Speedway are not for a C-20... That is a C-10 conversion... THe Dana or Eaton C-20 rears will not allow this type of conversion... there is no way to convert the Dana or Eaton to a 5 lug not to mention it is ALOT more cost effective to locate a 67-70 Rear if you are concerned about keeping the narrower track width or go to the 71-72 for a 1.75" wider track...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 11-10-2015, 01:39 AM   #8
ramses69
It is a 8 lug rear end. What year axles would work on that rear end or is there other year trucks that have rear ends that would fit?
Old 11-10-2015, 08:17 AM   #9
Elliot949
Elliot949's Avatar
On a C-20 running the 8 lug reared you are stuck with the 8 lug axle... even if you could change the axle to a 5 lug (which you can't) you would not be able to find a brake setup to fit.... Again the most cost effective way is to locate a C-10 rear differential...
Old 11-10-2015, 01:46 PM   #10
graymond1967
I have a dana 60 under mine with 8 lugs and would like to go back to the 5 lug wheels.
I would suspect finding a 67-70 rear could be difficult. Is there another rear, possibly with a limited slip, that would work with this truck? I assume that brackets would have to be welded on.
ray
Old 11-10-2015, 02:15 PM   #11
Elliot949
Elliot949's Avatar
ray
There are alot of options out there but these differentials for the C-10 are everywhere especially if you are good with a open carrier and not a P-trac... you should be able to find a bolt in application for 300 or less with the brake drums and all...
Old 11-10-2015, 03:24 PM   #12
Redline novdog
Anyone now what it will take parts wise to change the front to 5 lug?
Old 11-10-2015, 03:47 PM   #13
Elliot949
Elliot949's Avatar
Spindles, and brake...
Old 11-10-2015, 03:53 PM   #14
cooperhw
cooperhw's Avatar
I bought an 84 Suburban complete for less than $500. Pulled the front axle complete out and slid under my 1/2 ton frame. Drilled two new holes and elongated 2 (one each side). Instant 5 lug and disc brakes.
On the rear pulled one rear end out slid the other (5 lug) in place and installed. Used the u bolts off the donor (if I remember right).
Anyhow, buy a donor and swap em out if you want to do it on the cheap. If you want all new stuff, the new (donor) stuff can be rebuilt from any of the auto supply houses. MOOG is good.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 11-10-2015, 06:45 PM   #15
Redline novdog
Thanks guys! IMO why do you want to go backwards?? It's a truck haul something!!
