Old 11-08-2015, 10:36 PM   #1
Freddo
Radiator didn't fit quite right
I know this is pretty minimal compared to some of the things I see in here, but thought I would put it out there. My old 67 Chev longbox (283 with a turbo 400) has done quite a bit of work for me (on my days off) through the last summer. It's been running warm for a while now, especially on hot days or when I'm hauling a load of dirt or a trailer with some concrete. I've just taken it easy when I see the temp gauge climbing and figured I would replace or repair the radiator. The radiator is the 48 year old original, so it has every right to be tired. I spoke with a local radiator guy and he thought he could 'rod it out' and give it a new lease on life. He figured cost would be $125-$150 for the rodding out which seemed very reasonable as long as it did the job and to do a recore would be about $400. Ouch!
I have heard good things here about the way the Spectra 369 radiator fits and considering the inexpensive price (about $165 at Rockauto), I thought I would give it a try.
Got the radiator in and went to put it on. It doesn't quite fit. The rubber holders that fit inside the upper and lower mounting brackets won't fit over the larger flanges on the new radiator. We tried taking the rubber mounts completely out and it would fit, but that sure didn't seem right and I was pretty reluctant to start carving on these rubber mounts to make it fit.
My thought is to send the radiator back to Rock auto and to do the work on my original radiator, but thought I would see if anyone else here has had this problem with the Spectra?
Is there a real easy fix? Inexpensive mounting brackets that would fit?
I know there are some other radiator vendors on the board here and has anyone tried their products and had a true fit without carving up their mounts?
I took a couple of pictures to show what I mean on this. (I had already put the new radiator back in the box so it's a little tougher to see.)
All advice appreciated!
Freddo is offline   Reply With Quote
Old 11-08-2015, 11:54 PM   #2
Mmorgan32
Mmorgan32's Avatar
Re: Radiator didn't fit quite right
I had that problem when I put in my champion radiator I took the rubber out and slit a hose in half down the middle, fit it in the bracket, trimmed it so it fit in good and it fits like a charm now
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 11-09-2015, 08:48 AM   #3
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
There are two different style radiator mounts. 2-core and 4-core. Some vendors call the 4-core the HD mounts. They are wider, and likely what you need here.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 11-09-2015, 09:48 AM   #4
cooperhw
cooperhw's Avatar
I had the same issue. Modified my brackets and fits like a glove now.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 11-19-2015, 01:53 AM   #5
Freddo
Thanks everyone for the replies. They helped!
