1978 Blazer tachometer is not working
Hello K5 Team!!! I have a 78 blazer for awhile. The tachomemter and all the gauges wasn't working. I replaced all the gauges and an electrical board. Some of the gauges is working- the fuel pump and temperature works but the volts went too high #18 and oil pressure went too high as well. the tachometer still not working-- I checked the wiring-- one wire connect to the circuit board. One wire to grounds. Another wire went though the hood and connected with the capitctor. The capitctor isn't work-- according to the NAPA's rep. that the part I have is not for tachomemter?? I checked the distributor as well but there is no wires to the gauge. What do I need to do make it work? Right now, what we have is the brown wire from tachometer through the hood is connected to capitctor. I have attached the pictures of tachomemter wire, distributor and capitctor. Thanks for helping me out!
78K & 79C Jimmys
Re: 1978 Blazer tachometer is not working
did you get it figured out.
when I swapped idiot light to tach/gauges,I just used power from the cluster pink/black,no filter
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
