11-09-2015, 05:01 PM | #1 |
Powerglide
I have the powerglide and column shift 1966 c10. I don't have any of the linkage including the kickdown linkage. I could use some help finding that stuff if anyone has an idea where to look. I have been on the internet all day and I am still at zero. Or if someone has linkage.
Thanks Rocky |
11-09-2015, 10:20 PM | #2 |
Re: Powerglide
what engine do you have in your truck? The kickdown linkage is different for the inline 6 versus the V-8.
11-09-2015, 11:40 PM | #3 | |
Re: Powerglide
11-10-2015, 10:28 AM | #4 |
Re: Powerglide
I have the 283
pimpston65....so the linkage of some of the cars will too. |
11-10-2015, 04:32 PM | #5 |
Re: Powerglide
11-10-2015, 05:53 PM | #6 |
Re: Powerglide
LT1 Burb I will keep that in mind but I can buy a cable system that would work and have everything I need.... the shift linkage is what I really need.
11-10-2015, 07:09 PM | #7 |
Re: Powerglide
11-10-2015, 07:19 PM | #8 |
Re: Powerglide
The linkage off of the impala... are you talking about the kickdown or the steering linkage.
11-10-2015, 08:12 PM | #9 |
Re: Powerglide
11-10-2015, 08:14 PM | #10 |
Re: Powerglide
I need the shift linkage
11-10-2015, 08:58 PM | #11 |
Re: Powerglide
11-11-2015, 02:34 AM | #12 |
Re: Powerglide
11-11-2015, 02:59 AM | #13 |
Re: Powerglide
Lokcar told me that their shift linkage wouldn't work on my powerglide
11-11-2015, 03:58 AM | #14 |
Re: Powerglide
well, I have seen where you can weld the pivot bracket thing to you frame, same location where the z-bar for manuals would be located, that was cut from another frame and make it work. the other options is convert to floor shifter.
11-11-2015, 10:24 AM | #15 |
Re: Powerglide
I have the automatic frame with the pivot bracket
11-11-2015, 11:12 AM | #16 |
Re: Powerglide
what exactly do you need? now that we know you have that bracket.. is it the rods from the trans to the steering column or the linkage from the trans to the carb. as LT1 says he has the piece that bolts to the block which is a bellcrank that bolts on where the b/h meets the back of the block. there is an expanded view I believe in the assembly manual. perhaps look at that to see the pieces and define what you need, when you say you need p/g linkage then that frame bracket is part of it
ron |
11-11-2015, 12:03 PM | #17 |
Re: Powerglide
I just meant that I have the automatic chassis. And so I have the part that is welded on for the pivot part of the linkage. I have no linkage what so ever.
11-11-2015, 12:15 PM | #18 | |
Re: Powerglide
as I told you before I have all 0of the pieces but you seem in a hurry and I have stuff in different containers and I don't have the time right now to perhaps spent a couple of hours digging to pull it all out and for you to say oh! i already got it somewhere else ron |
11-11-2015, 12:26 PM | #19 |
Re: Powerglide
I think if you are not worrying about stock that you should just use the Lokar linkage.
http://www.jegs.com/i/Lokar/625/ACA-...oductId=749836 Just adapt it to the powerglide trans bracket and use regular carb kickdown linkage. Trying to find stock linkage is like looking for hens teeth. |
11-11-2015, 12:28 PM | #20 |
Re: Powerglide
I need all the pieces I still haven't found anything yet. How long will it take you to look. and how much will you want for everything. Sorry for the misunderstanding it is hard to communicate on a forum so if I could call you that would be great.
11-11-2015, 02:38 PM | #21 |
Re: Powerglide
If Padresag has it all I would buy it all as you will have a hard time locating any of it elsewhere.
11-11-2015, 02:41 PM | #22 |
Re: Powerglide
some more pics of what is required.
11-11-2015, 07:24 PM | #23 |
Re: Powerglide
11-15-2015, 06:34 PM | #24 |
Re: Powerglide
I did send you a PM 3 days ago
ron |
