Relacing factory rivets.
I was wanting some advice replacing factory rivets. I'm working on 71 Chevy fleetside frame. Im wanting to replace the rivets on the cross members. What would be the best bolt, or would it even be a good idea to replace the rivets??! Thanks.
Posted via Mobile Device |
![]() Join Date: Oct 2004
Re: Relacing factory rivets.
If they are fine I would leave them alone, but if not use grade 8 hardware. I replaced some of the rivets on my Burbs frame that were bad and that's what I used.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
The Older Generation
I agree with rocknss. Grade 8 bolts and make sure they fit the holes snug. If you have to, drill the holes out to the next bolt size to get the closest fit possible. LockDoc
My advice, if you drill do it one rivit at a time to maintain the geometry of the frame.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I appreciate the feedback
