Old 11-10-2015, 03:00 AM   #1
C10forDad
Towing with a 5" drop question?
I am in the beginning stages of a build and was wondering if anyone here has used this system.
https://www.performanceonline.com/60...de-assist-kit/
C10forDad is offline   Reply With Quote
Old 11-11-2015, 05:34 PM   #2
SCOTI
SCOTI's Avatar
Re: Towing with a 5" drop question?
What is your 'plan' to achieve the 5" drop?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-11-2015, 07:35 PM   #3
C10forDad
I have a pair of ECE 5" drop springs. I also flipped the stock trailing arm brackets that attach to the cross member.
This will be a daily driver and I don't want to do a full air ride suspension.
Old 11-11-2015, 08:12 PM   #4
7dee2
7dee2's Avatar
Didn't use that kit exactly but something similar with leaf springs and helper bags. Here's some pics of our setup at the time. The only problem we had is it eventually broke both frame rails in the c-notch area after years of use. If we were to do it again that's the area I'd focus on.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 11-11-2015, 08:13 PM   #5
SCOTI
SCOTI's Avatar
The kit looks like it would work as a helper w/your coil set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-12-2015, 03:19 AM   #6
Slow Build
Slow Build's Avatar
x2
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-12-2015, 05:58 PM   #7
7dee2
7dee2's Avatar
Coil or leaf, I would still be concerned with the c-notch area that will be the weak link in your dropped towing plans. The helper bags worked really well for us and was great to compensate for the tongue weight. This is what we went to when we couldn't use the 68 GMC any more. The 99 C3500 did work better also with helper bags but again rear leaf suspension.
Brett
Old 11-12-2015, 06:15 PM   #8
SCOTI
SCOTI's Avatar
I agree w/the c-notch concerns. I wouId do a HD CPP notch or Porterbuilts multi-piece set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-12-2015, 08:57 PM   #9
Slow Build
Slow Build's Avatar
I also think the c-notch is the most important focus when your talking about towing with a 60-72 C10. It doesn't help that the frame curves right where the notch is installed. I had a 89 C1500 that I put a Bell Tech notch in. Because the area where notch was installed was straight the bolt in notch section can be a lot longer distributing the stress over a larger area. I felt pretty comfortable towing with that and air bag helper springs. The 60-72 C10 is a completely different animal. I would only use a notch that is specifically for towing for starters. I think Porterbuilt, CPP & Western Chassis make them. Even then I'd be cautious.
I was originally planning on doing that same air bag set-up. I've changed directions and am now going with replace the coils with air bags. One thought I had, and I don't know if it would be a positive or a negative, was that the original suspension supports the load from the frame in front of the wheels only. That kit will add it's support form the rear of the frame past the notch. I don't know how that would change the stress on the frame. The reason I changed my direction is because I'm moving the gas tank to the rear and I'd like to have the exhaust to exit behind the tires. Just a little too much going on in the area.
Past GM Trucks:
Old 11-13-2015, 12:23 AM   #10
SCOTI
SCOTI's Avatar
Keep in mind that leaf spring arrangements add more stress to a c-notched frame vs Truck-arm/coil set-ups because of the extreme rear pick-up point for the leafs on the frame rail. Coil set-ups keep the stress in front of the rear notch. Towing forces @ the rear of the frame would be the same for both.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-14-2015, 02:34 AM   #11
C10forDad
I did go with the HD CPP c-notch kit and plan to bolt and weld them in place.
Old 11-22-2015, 03:23 AM   #12
68c10airstream
68c10airstream's Avatar
I have 4" dropped springs in the rear of my 68 c10 and pull a 2500lb airstream with absolutely no sag in the rear because i use leveling bars and the added feature of sway control. No "C" notch though, so not a fair comparison. Trailer sits level and the truck sit as if it wasn't loaded down. It actually rides and tows better pulling the airstream using the leveling bars than putting 1,000lbs of pavers in the box and driving home from the lumber store. My setup is the style that has a step block on the end of the bars and causes the trailer to lean into the turns.
Towed the airstream at 80 mph and been in pretty good cross winds and it works great. Call me crazy but i know what it can do and what to expect out of it.
68c10airstream is offline   Reply With Quote
Old 12-31-2015, 10:47 PM   #13
wraprail
wraprail's Avatar
No issues
wraprail is offline   Reply With Quote
Old 01-01-2016, 07:33 AM   #14
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
If your purpose is for towing assistance then you definitely need to get more specs on that specific kit. Sleeve bags of that sort CAN carry very low ratings for load capacity and it would be better to have some data before buying a random kit.
I am not saying that sleeve style bags are not good for loads as almost every air-ride 18 wheeler on the road would disprove that statement. I'm saying you should consult the manufacturer of the kit or the manufacturer of THOSE bags to figure out if they are rated for what they say they are intended.
Like everyone else mentioned an airbag can increase your safe load capacity by a very nice margin as long as you factor in building a nice strong C notch if you go that low.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 01-01-2016, 09:32 AM   #15
99RegalGS
I have that kit on my 71'. It took me about 3 hours to install. I haven't had it on the truck very long, but it has prevented bottoming out the rear suspension the couple times I've used it..
-Sean
1971 C10 - 5.3 LM7 + 4L60E
99RegalGS is offline   Reply With Quote
Old 01-01-2016, 12:51 PM   #16
slotard
I agree with everyone else regarding potential problems with a notch. I don't think I'd want to use a truck with a notch and stock bed floor very hard. If you do, inspect it very often early on (look for cracks), that might mean you find a problem before it causes a crash. I'm not questioning anyone's fab skill, just the significant decrease in strength thanks to a notch.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-02-2016, 05:25 PM   #17
HAULIN' IT
I'm a bit late posting since I see you already have the notch done. I didn't use that kit, however some of the concerns (& solutions) could be the same from my '86 & your older truck.
As I was building our truck, I looked at the "normal" way some things were typically being done & came up with what I feel is a better way to end up sitting "right" without compromising the frame, usability, ride, ect.
I don't tow with my truck, however I do often haul 400-600 lbs. which would for sure create some problems with the suspension clearance once the leaves were softened up a bit for a better launch.
I started out by doing a 0"-2" (front to back) body drop. This way, the truck looks the same at the wheelwells, but has 2" more clearance between the axle & frame than a truck with a traditional flip & notch. This also did some other things like hide the frame, fuel cell, battery, ect. compared to a typical drop.
I added airbags on some altered/home-made mounts for times when I have some weight in the bed...keeping the same 2" between the axle & snubber.
HAULIN' IT is offline   Reply With Quote
