Old 09-15-2003, 10:37 PM   #1
billsbowtie
billsbowtie's Avatar
? about a fuse
my brake light and park lights same fuse gets hot when i put it in i cant find no bad wires it sparks and turns red but has not blown i only use it when i drive at nite can anyone help thanks bill
billsbowtie is offline   Reply With Quote
Old 09-15-2003, 10:42 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I had the exact problem, turns out the wire going to my lisence plate lights (they were hooked up to the parking light circuit) had a hole worn in the insulation and was grounding out on the frame.
Check the wires going to your parking and marker lights to look for any obvious holes in the insulation.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-15-2003, 11:00 PM   #3
billsbowtie
thanks yellow72custom i will check it out
i have 67/72 chevy truck parts f/s.
Old 09-16-2003, 02:24 AM   #4
Hooter
My other Love
Hooter's Avatar
well check for holes and pinched wires between your fenderrs etc... also check the wire that used to be used for the illumination on your factory radio, might be lightly grounding on something, having a glowing fuse like that is just asking for a fire
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
