Old 09-15-2003, 10:42 PM   #1
hank
stabilizer bars
someone told me this weekend that stabilizer bars did wonders for his handling on his '70 chevy.
does anyone else recommend this? is it a hard job?
hank is offline   Reply With Quote
Old 09-15-2003, 10:45 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Everyone i know that has put one on said they make a huge differnce. I dont have one yet but i plan to install one soon.
It isn't a hard job. You need to locate a front sway bar first. Any bar from a '67-87 1/2 ton through 1 ton truck will work. I would look for a beefy 1-1/4" thick bar off of a 1 ton if possible. The bigger the bar, the bigger the difference. It should be easy to come by at any salvage yard.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-15-2003, 10:52 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
night and day.
My GMC feels liek the door handles are about to smack the pavement if I corner above 25MPH, but the old 70 loghorn I used to have (which sat quite a bit higher) felt flat and stable in corners. I was once told that the front tires looked like they were about to roll off the rims. I know that guy liked to exadurate, but it sounds good.
Old 09-16-2003, 01:46 AM   #4
Hooter
My other Love
Hooter's Avatar
adding just a front stabalizer makes a world of difference. I reccomend finding a camper special 73-80 chev truck with the inch and a half front swaybar. in the rear there are kits avaliable from the aftermarket if you have trailing arms. I have also seen people adopt rear sway bar set-ups from 2nd gen firebirds and camaros
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-16-2003, 11:09 AM   #5
dubie
dubie's Avatar
I picked one up at a local yard for $20 and that included all the mountings as well. I haven't installed it yet but I will be doing so before my truck gets back on the road
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 09-16-2003, 11:29 AM   #6
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
It’s the best improvement for the money by far
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-16-2003, 12:55 PM   #7
1971 Cheyenne
1971 Cheyenne's Avatar
hmmmmm, I have a dilema on my hands
I have the stock 1 1/16 inch away bar in my ride. I just bought new bushings and straps for it from early classic.
I have this 73 camper special that has the 1.5 inch sway bar and i'm sure it would be ok if i jacked it from that truck.
You guys think it would be worth the extra hassle to go for the bigger one???
I'd have to selll the old bushings and straps, and by new ones for this sway bar.
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 09-16-2003, 01:11 PM   #8
phase_one
Hey 1971 cheyenne What does the mounting kit you bought go for? Or if you decide to see what will yours go for? I'm looking for a kit for that size sway bar.
11 Surbaban
70 C 10
still in progress
phase_one is offline   Reply With Quote
Old 09-16-2003, 01:26 PM   #9
1971 Cheyenne
I bought it from Early Classic Enterprises.
It cost me 29.00 and includes new bushings, new straps, and all the bolts required to mount the sway bar.
I'm not sure how much I would sell it for IF I do decide to go with the bigger bar. Less, i'm sure...
'71
Brian Pal
Old 09-16-2003, 08:12 PM   #10
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Do the 73-87 bars bolt in with no mods or problems? Do you have to use 73-87 mounting hardware, or can you use 67-72 hardware? What do I need and what should I replace when I put one in my truck? I don't have any mounting brackets on the frame, because mine never came with a bar on it. Can I use 73-87 brackets, or do I need the 67-72 brackets, and where can I get them? Sorry for all the questions, just would like to know what to look for in the yards.
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 09-16-2003, 09:26 PM   #11
Lobo'74
Lobo'74's Avatar
Anti-sway Bars
My '67 came with BIG anti-sway bars front and rear. The last owner put 'em on when he put in the rebuilt '79 350. Don't know what it handled like before, but I'm purdy impressed with it now. Hardly any body roll in corners. My 16 year old wants some on his '88 volvo now. Hey, no cracks about the volvo. Its the perfect teenage car. 4 cyl, 4 speed auto, and it crushes well if needed. Actually, he wants a truck too, but he likes '69 and up.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 09-16-2003, 09:57 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The 73-87 bar is a straight bolt on deal. The frame brackets are the same for your truck as well as 73-87s. You can buy them at the dealership for cheap if you need to, or Early Classics sells special ones for lowered trucks for 19.00 per pair. You will need to grind off the two rivets that are in the frame now and bolt the brackets on using the holes from the rivets.
Old 09-17-2003, 11:07 AM   #13
72c10step
72c10step's Avatar
Thanks TX Firefighter! Now only if the weather was supposed to be good this weekend!
-1984 Jeep CJ7
-2003 Honda 300ex
Old 09-17-2003, 03:38 PM   #14
72c10step
72c10step's Avatar
Oh and a few more questions . I doubt it, but is a 4x4 sway bar compatible, and also van sway bars, I saw a few in a yard recently, and they looked too tall and long, but aren't the suspensions the same?
-1984 Jeep CJ7
-2003 Honda 300ex
Old 09-17-2003, 10:58 PM   #15
Longhorn Man
I dunno about the 4X4...but the van is a no-go if memory serves.
I think the truck is wider.
Old 09-18-2003, 05:27 AM   #16
Brad
Out of the carpool lane.
Brad's Avatar
Let me know if you're interested in the one in my signature.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-18-2003, 11:29 AM   #17
72c10step
72c10step's Avatar
hank, sorry for hijacking the thread.
Brad, I'll keep it in mind. Right now I want to check the local yards, and *hopefully* find one of those nice big 1 1/2" bars from the camper specials.
-1984 Jeep CJ7
-2003 Honda 300ex
Old 09-18-2003, 11:47 AM   #18
hank
hey, no problem.
just sittin' back, readin' and learnin'.
thanks for all of the input, guys.
Old 09-18-2003, 12:44 PM   #19
70short
YA! I am learning alot off this forum THANK YOU ALL
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 09-18-2003, 12:55 PM   #20
lewi
lewi's Avatar
How about this other guys who read and learn, welcome to the club. I've been doing it for a few years on this board. finally registered last year when i had a a couple of qestions I hadn't found.
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 09-18-2003, 05:37 PM   #21
SCOTI
SCOTI's Avatar
I've seen 1 1/4" HD bars & I even have one on my 74 that came from a 1 ton dually flatbed.... but I've never seen or heard of a 1 1/2" bar. Have I led a sheltered life?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-18-2003, 08:23 PM   #22
Dusti
Not Dusti,just Bob
Dusti's Avatar
I have never seen 1-1/2" swaybar,I have a 1-3/16 bar that I'am going to put on my 3/4ton,It looks alot bigger than the 1-1/16 bar that was on it.
the parts that hold the bushings are only 2" wide that would not leave much room for the bushing,Maybe they use different hardware.
Bob W
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
