Old 11-10-2015, 09:33 PM   #1
bluek5
bluek5's Avatar
TCI 2244 rear springs, lift heigth
I have a 72 Blazer with what I believe is a four inch lift. Front springs and rear blocks. I recently found and bought some TCI Tuff Country 2244 52" rear springs from a 87 Suburban. My question is what kind of lift can I expect to get from these springs? I bought a complete 4" all spring lift for one of my other trucks. The rear springs that came with it were TCI 2216. I would like to drop the rear end of my Blazer just enough to level it out. Any thoughts or experience with the 2244 springs?
Thanks, Paul
bluek5 is offline   Reply With Quote
Old 11-10-2015, 10:44 PM   #2
Mike C
Mike C's Avatar
Re: TCI 2244 rear springs, lift heigth
Tough Country probably better to ask. I would think most of us don't have experience with different part #'s of one manufacturers springs.
Personally, I thought you were hoping to raise the rear up a little? I like it where a level on the bedside is level personally. Kind of hard to tell if that's the case in your pic.
I have Rancho 4" springs in front of mine and some National 4" 52" rears. Fronts went on in '89 and I bent the crap out of the perches with the blocks and the Nationals went on in '90.
This is the only pic I had uploaded so you can't tell a whole lot.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-10-2015, 10:59 PM   #3
bluek5
bluek5's Avatar
Thanks for the reply. It's not a very good picture, but the rear is a little higher. I will have to give them a call and see if they an give me any information.
Old 11-11-2015, 05:08 PM   #4
bluek5
bluek5's Avatar
So, I called and asked about the TCI 2244 rear leaf springs. They are a 52" 4" lift spring. It turns out that the 4" lift I bought for one of my other trucks with a TCI 2216 rear spring turns out to be a 6" lift. I guess I will give the 2244 springs a try on my Blazer when I can.
Thanks, Paul
