Cab lifting ideas...
I finally got the truck stripped down to the frame. The cab was much heavier than expected. I do not want to put it back on the way I took it off(with 3 people). Lets hear some ideas for cab lifting/moving, and lets see and contraptions you may have made to move the cab or bed around...
Thanks...
1972 C10 1972 C20 ![]() |
Two words....John Deere..
That is what a back hoe is all about |
on my 65 we used an A frame and took the doors off of the truck, stuck chaing through the cab and put moving blankets around it so not to damage the truck and lifted it right off.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
If you're doing this in a place where you have rafters overhead, you can rig up a chain hoist or come-along several ways using straps and/or 2X4s under the roof of the cab.... shouldn't be hard, get creative.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
#5 | |
Bloo
well, like phillip, i have 2 words, but i choose a different color..... Massey Ferguson
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Chevelle454,
I came across this post about a month or so back here on this forum. Check out the link below. It involves a cherry picker. Interesting way to pull a cab ![]()
72Chevy swb 4x4 71GMC swb 2x4 |
![]() Join Date: Jan 2001
I was thinking, like... 4 guys? 5 guys? 6 guys?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
cherry picker is the we do it
Glowing since 1978
Here is a link to Duallie's web site and his pictures of moving his cab on the car carrier he is building. You can select wooden cradle highlight to see the cherry picker position. Hope Duallie doesn't mind. http://www.ptialaska.net/~nickel/index.html
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
Cantankerous Geezer
I like the engine hoist idea. What did he attach to for lifting?
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Post Whore
![]() Join Date: Feb 2000
I recall someone recently mentioning the engine hoist idea. I don't recall how they said they attached it to the cab.
What would you guess a stripped cab weighs, i.e., gutted interior, doors or glass?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#12 | ||
F.A.S.T. president
![]() Join Date: Sep 2003
Only one word from me.........Kubota |
#13 |
Kubota... Not enough lift! Tow strap through the doors (with the windows down) and disconnect all ground straps and the SPEEDO cable (Ive made that mistake) and bingo, swing it slowly out of the way. The cherry picker is yet another way. You just need to go through the trans hump and use a few pipe supports and then secure it from front to back and be sure its balanced. That works too but it sometimes takes 2 people. The John Deere method is a one person deal and then you can say ouy did it yourself! As long as you get it done, damage free. you have it made and no one goes to the hospital!
#14 | |
F.A.S.T. president
#15 |
Phillip
Phil;
You need to demonstrate that tractor technique and put that motor out of your red 72 on my engine stand!!
Bob |
#16 |
![]() Join Date: May 2002
my dad and i did it by ourselves. 2 guys and a 2x4
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#17 |
GOT JACK???
i got a smoking, flathead, runs on 2 out of 4 cylinders Hyster forklift with 6 foot long forks. seems to do the trick. works nice on pullin beds, also makes for tool less engine removal on junk cars!!
68 C-10 250", 200R-4, LWB 04 F350 dually V-10, 6-spd 72 Cadillac Coupe DeVille |
#18 |
Next!
Same as above, a 58 hyster H50 and a 58 IH 340 Utility w/ forklift attachment, both work for lifting beds, cabs, and whatever else, ask old Rusty C10, that's how we got the cab in his Ranger!
GM
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
#19 |
Thanks DDSmith... I built a beam out of two 2x6's and sawed some small grooves in the top to locate on the weatherstripping lip at the front of the door openings. Then I drilled the tip of my engine hoist so I could run a bolt out the top of the hoist arm, sticking out an inch or so. Then I drilled a matching hole in the bottom of the 2x6 beam in the exact center to receive the bolt spike. You can see in my site how well it worked.
TRUCK UPDATE: I rebuilt the 513 Cadillac, the Turbo475 got some Allison parts, but I'm fighting the approach of winter and more important projects have to be completed.
Just as if I knew what I was doin' |
