11-10-2015, 10:20 PM | #1 |
anyone cut the gas tank holder tabs out?
I relocated the gas tank, and am wanting to put a sub box behind the seat. Trying to figure out if it is worth the trouble to cut the mounting tabs off or just build the box around them. Thanks.
11-11-2015, 01:46 AM | #2 |
Too many projects
Re: anyone cut the gas tank holder tabs out?
I used them to secure my box, easy to do and strong enough to keep it from rattling.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
11-11-2015, 01:16 PM | #3 |
Old member
I also used these tabs for securing my box in place.
11-12-2015, 06:37 PM | #4 |
Did you guys use 1/2 in or 3/4 in mdf?
11-12-2015, 08:26 PM | #5 |
Old member
Mine was 3/4" and I used thin 1/4" for the backside up against the cab wall.
It's not perfect but the 10" subs will hit pretty good when I turn it up.
11-13-2015, 01:53 PM | #6 |
your tank might rusty, and all corroded inside, so if i was you, i would just avoid cutting up your tank, that can just make more problems. Especially where it's so easy to build a bracket
11-13-2015, 02:55 PM | #7 |
I wasn't going to cut the tank, it is already gone. I was talking about cutting the tabs out that are in the back of the cab that the tank bolts to.
11-13-2015, 03:07 PM | #8 |
I used those tabs to hold the my subs and speakers down, which works really well, i don't know how things would work if you cut them out, so i can't help you there, sorry
