Old 11-10-2015, 11:34 PM   #1
Hblee
Hblee's Avatar
Napco questions
So my plans for a BBC powered 57 may change. My ex BIL came across a basket case 57 3100 Napco outside of Monroe, LA. Before I drive up there to take a look is there anything special I should know? Like are parts hard to find? I'm sure it will need the front and rear axles gone through plus the transfer case. I'm thinking I will just swap the Napco stuff on to my frame since it is really nice. I would be using my original 265 and a friend has an SM420. Thoughts?
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida that she's cherry.
Hblee is offline   Reply With Quote
Old 11-11-2015, 07:40 AM   #2
1project2many
Re: Napco questions
NAPCO drivetrains are always cool imo. But switching to the old axles means moving your truck from driver to collector truck imo. The gear ratios are not highway friendly (usually 4.56:1) and if something breaks the replacement parts are difficult to obtain. True, these axles are pretty tough but they do still need repair and maintenance to keep running.
If a frequent use 4X4 is in the plan then I'd suggest using parts from a more modern drivetrain.
1project2many is offline   Reply With Quote
Old 11-11-2015, 01:44 PM   #3
Purcell69
Re: Napco questions
If it is a true NAPCO, "NAPCO" will be cast into the axle housings and transfer case. Like was said above, the gearing is not highway friendly. An acquaintance had one that she drove every day to school back in the day. At 45 mph, the motor was wound up pretty tight. As I recall, the gear ratio in the axles was even higher than 4,56, more in the neighborhood of 5.xx so even a tall tire is little help.
A few weeks ago I found a set of axles and transfer case on eBay out of Wisconsin. The seller was looking to get $1500 just for the parts. From a collectable standpoint it works be cool and worth saving from the scrap yard. As a driver, you'd be better off switching to modern axles if you want to build a 4wd
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 11-11-2015, 02:14 PM   #4
Hblee
Hblee's Avatar
Re: Napco questions
This is all interesting. I think that the 3.90 was the highest ratio offered, 4.57 and 5.14 were optional. I really don't have a clue what gears are in this thing. I read that the 3.38 gearset from Patrick's and others will work but I would end up spending a bundle changing them over plus the other parts. I've also read the NAPCO front axle had some oddball brakes from a Studebaker (??) and some of that stuff is hard to find. Even if the NAPCO stuff had the 3.90 gears the 265 would be wound up going down the road.
I'm not sure yet, I've always liked the NAPCO trucks but I also like BBC, auto, p/s and p/b, a/c and being able to go on a short trip.
Thanks for the replies and advice.
-Joe
Old 11-11-2015, 03:57 PM   #5
OrrieG
OrrieG's Avatar
Re: Napco questions
Everything you want to know about NAPCO trucks.
http://napco4x4.org/
"Modern" 4x4 usually have a 3.73 ration with autos, 4.11 with standard transmissions. 265 will rev a lot more than a stock 350, I ran a 283 .30 over from 85 to 2000 with no issues at highway speeds (3.73 rear). In addition to the cast logo the transfer is divorced and way back, so they have a long front driveline and in/out lever. May or may not have the fender trim it was shipped in the box and up to the customer to install. Should have the shift pattern instructions on the dash or inside the glove box lid, sometimes they stuck them on the cab roof above the windshield too. Worth saving but PITA if they break.
OrrieG is offline   Reply With Quote
Old 11-11-2015, 04:30 PM   #6
Purcell69
Re: Napco questions
I know what you mean about the BBC. I built one and installed it in my wife's 1978 C10. There is no describing the smile on her face the first time she got in to the throttle. At one point, I had the parts to put a BBC in my build, but when fuel prices went crazy after 9/11, I sold off all my big block stuff and rebuilt the 350 that came out of her C10 for use in the 57. Now it's sitting on a dolly and I have a Magnum 360 ready to go in.
The 454 is a fun motor and can take a lot of revs, but it gets pretty monotonous listening to it going down the highway with a set of 3.73 gears and no overdrive. I finally swapped out her rear end for a 3.07 geared rear. The motor had more than enough torque to pull those gears and crazy wheel spin if you wanted to "put on a show", lol.
-Joe
Old 11-12-2015, 11:53 PM   #7
bajabob
bajabob's Avatar
Re: Napco questions
Hblee
You asked for opinions so here is mine.
I love the hotrod/ratrod scene and will build one in the future but I wanted something different for my long bed. I found the Napco stuff and you just don't see it out there that much. I like the lifted skinny tire look and my truck is really just going to be a surfboard hauler to the beach and back so I am not really worried about speed. I wouldn't mind doing some jeep trails in the local mountains and maybe out in the Az desert but obviously no pre running!!! lol !!!
It is a little more challenging to find the Napco stuff but it is out there or can be machined. I would score the Napco especially if its original (check to see if the transfer case brackets and shifter brackets are riveted to the frame which should indicate a factory install, although it would be easy I have been told to reproduce the rivets and make it look factory???).
bb
bajabob is offline   Reply With Quote
Old 11-16-2015, 04:59 PM   #8
Hblee
Hblee's Avatar
Re: Napco questions
So I've exchanged a few emails with the guy. It has 3.90 gears and allegedly all of the NAPCO running gear is in really good shape. I had intended to take a ride up there on Saturday but it looks like it will be after Thanksgiving before I can go.
He says it's a real RPO 690 factory built 4wd. We'll see. If I can get it right I think I'll go ahead and pick it up.
Old 11-17-2015, 09:29 PM   #9
Purcell69
Re: Napco questions
Best of luck. It is good that you are looking at it first hand. I saw someone advertising a "NAPCO" last night (I can't remember where), all original, etc. it had a 350 V8 and non-divorced mount transfer case. Clearly not an original NAPCO for 1957.
-Joe
Old 11-17-2015, 10:06 PM   #10
1project2many
Re: Napco questions
Well, Napco or not it sounds like he gets credit for doing his reasearch. Not too many folks know the correct RPO.
Old 11-17-2015, 10:11 PM   #11
Purcell69
Re: Napco questions
Very true. That is a good sign for sure.
Here's spare parts for one, or a conversion kit:
http://albuquerque.craigslist.org/pts/5288015474.html
-Joe
Old 11-19-2015, 02:00 PM   #12
Hblee
Hblee's Avatar
Re: Napco questions
Dang, I'm gonna need that drive shaft that runs from the SM420 to the transfer case.
-Joe
Old 11-19-2015, 05:36 PM   #13
OrrieG
OrrieG's Avatar
Re: Napco questions
Get a sm420 output piece or complete drive line. Measure the distance from the output piece midway in its travel to the centerline of the transfer universal joint. Take the measurement, output piece and transfer case to a driveline shop and they can make one for you for less than the price of finding a "correct" one. If you have the complete drive line they will be able to figure out the transfer case universal joint, there are ones made for adapting different sizes.
Old 11-19-2015, 07:15 PM   #14
bajabob
bajabob's Avatar
Re: Napco questions
I have had several driveshafts "made" not an issue at all. Getting all the right parts way important!! I.e. Shifter brackets and linkage!!! Correct axles and transfer case. If you can find a tc with the pto for a winch!!! That would be way cool!!!
Bb
Old 11-28-2015, 11:37 AM   #15
Hblee
Hblee's Avatar
Re: Napco questions
Thanks for the advice, fellas. I finished cleaning my dad's garage out last week and found a SM465 yoke, a T400 yoke and I have a couple of smaller yokes for a Muncie and the original 3 speed. It's been a while since I've had an SM420 so I'm not even sure what type of slip yoke it uses but I bet I can round one up. I have a couple of driveshafts laying around so I should be able to come up with something that will work.
I wanted to go look at the stuff last weekend but the guy was out of town for the week of Thanksgiving. He then wanted me to come this weekend but I can't, my daughters are both down for Thanksgiving. We are going to try again next weekend, I might even try to take a day off during the week for a road trip.
Old 11-28-2015, 12:37 PM   #16
Hblee
Hblee's Avatar
Re: Napco questions
Well after a quick search on Google and I found out that an SM420 doesn't use a slip yoke. All of the parts seem to be available from quite a few places.
Old 12-02-2015, 03:05 AM   #17
G&R's57GMC
G&R's57GMC's Avatar
Re: Napco questions
My '57 GMC NAPCO was factory installed . It has 3.90 gears. With the stock tires it was a screamer at 60 mph so I installed the tires from my Avalanche that are 32" diameter on 16x7 wheels. Now it will cruise at 65 mph all day without breaking a sweat.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 12-18-2015, 05:27 PM   #18
Hblee
Hblee's Avatar
Re: Napco questions
So I finally got to go look at some NAPCO stuff that a guy in the Texas Hill Country had for sale on Craigslist in Austin. I loaded up a friend's trailer and had a nice road trip yesterday. This guy and his dad have really got the Task Force trucks. His dad said at one time they had over 200, but had sold quite a few and were trying to get down to 60 or 70. They are on a 400 acre place so they have plenty of room. There was a sea of old trucks. I counted at least 5 Cameos and they were a dozen or so Suburbans, and a panel truck or two. There probably 20 big window cabs. Most of the trucks that were lined up are pretty rough, lots of rust and most would be considered basket cases IMO.
They had 4-5 NAPCO trucks and a NAPCO Suburban plus a 57 and 58 rolling chassis. I wanted the 57 but the 58 was so much nicer, plus it had 16" wheels on it. I ended up getting it and got everything but the short driveshaft to the transfer case and the linkage from the shifter to the transfer case. He only had one set and didn't want to part with it. Honestly it didn't look like much, I think I can make something pretty close with an old shifter rod, some flat stock, clevis pins and a few other parts.
So I think I did all right, I had to pay a little more because of the 16" wheels but at least I won't have to be searching for a set of them.
This was my dad's truck and he liked original stuff, so in honor of him I'm going to restore it as close as possible to how a NAPCO would have been new. I wish he was still around the help work on it.
I dropped the frame off last night at a friend's repair shop. He's going to take it all apart and then I'll decide how deep I need to get into the front and rear diffs, whether they need a total rebuild or just some bearings and seals and a new paint job and new brakes. The transfer case was just rebuilt (allegedly) so I"m hoping it won't need anything but some paint squirted on.
I'll post some pics when I get it presentable.
Old 12-19-2015, 05:15 PM   #19
OrrieG
OrrieG's Avatar
Re: Napco questions
58 frame is easy to use for 57 only difference is the front frame is extended about 2.5 -3" because of the longer 58-59 fenders and extended grille.
Old 12-20-2015, 12:27 AM   #20
Hblee
Hblee's Avatar
Re: Napco questions
OrrieG, my 57 frame is pristine, smooth, no pits, the VIN and all of the little stampings are there. I'll be swapping the 58 parts onto my frame, I'll just need the usual longer brake hoses, parking brake cables, etc. The 58 frame still has the original spiral shocks but there have to be some shocks that will work. The driveshafts I got are from a swb truck.
The blocks that are on the rear are different from the other NAPCO trucks I looked at. These have a protrusion sticking out similar to a small anvil that would contact the bump stop. The other lift blocks were square.
So it's time to get started on the 265 and find an SM 420. I want to have the frame done this winter.
Old 12-20-2015, 10:14 AM   #21
1project2many
Re: Napco questions
The "bump stop" blocks are something I've seen on other NAPCO trucks. Can't tell you if they're original, though.
Old 12-20-2015, 07:03 PM   #22
Hblee
Hblee's Avatar
Re: Napco questions
He had 3 original line built NAPCO trucks, the frame I bought was the only one that had these bump stops as part of the lifting block. This frame also had an extra set of leaf springs on top of the lower stack. The extra stack was also 5 leaves and shorter and the u-bolts looked to be about 3" longer. It all looked original and not added on but who knows when you're dealing with stuff that is over 50 years old.
The frame I got is from a GMC, the other 2 were Chevys. I'm not sure if they were configured different from a Chevy but it would appear that way?? I'm a NAPCO newbie and I have a lot to learn and figure out. I found more good info from the Stovebolt site than I did the Napco 4x4 owners website.
