Old 09-15-2003, 10:52 PM   #1
DINS 1
DINS 1's Avatar
AUX Heat in a burb
anybody have pictures of a aux heat unit in the rear of a burb? I would like to add on if i can find one and its location does not mess up other plans i have.
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 09-16-2003, 01:56 PM   #2
71sub
71sub's Avatar
I never new this year subs have AUX heater boxes in the rear?
Was this dealer add-on or OEM ?
Any ideas of donor vehicles for this ?
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 09-16-2003, 02:50 PM   #3
mindhive
Flex-a-lite makes a prety nice one. Read a review in some 4x4 mag. They put it in a jeep and it supposedly worked pretty good.
mindhive is offline   Reply With Quote
Old 09-16-2003, 02:58 PM   #4
mindhive
BTW its available from Summit for 149.95. manutacturer is flex a lite consolidated, part number is 640.
Old 09-16-2003, 05:32 PM   #5
grebus1
grebus1's Avatar
To my memory, the auxiliary heater was located under the 2nd (center) seat. There is at least one pic in the original accessories brochure for 1972. I have one, but unfortunately don't have a scanner. Maybe someone can provide a scan if they have this brochure. I think the aux heater is also covered in the original 1972 service manual.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 09-17-2003, 12:28 PM   #6
grebus1
grebus1's Avatar
Did some checking last night...according to accessory catalog and service manual, aux heater was a dealer-installed accessory. In the Suburban it was located under the 2nd seat, in the panel it was on the left side a little further back. The service manual provides multiple pictures and a thorough description of how the system is designed.
Old 09-17-2003, 09:35 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you are planning aftermarket AC maybe using a small coupe'/pick-up type unit would fit and have an auxillary heater.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-17-2003, 10:14 PM   #8
Duallie
Duallie's Avatar
I don't know if its original or not, but my '71 1/2 ton 4X4 Sub has rear heat. It appears identical to the '73-up heater box, but mine is on the drivers side back corner whereas the '73 up is on the passenger side back corner. The control switch doesn't appear aftermarket, and is located exactly where the aux tank select switch was on a parted-out cab I had(on the extreme left side of the dash metal). Alaskans NEED rear heat in a suburban!
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
