11-11-2015, 02:46 PM | #1 |
Smaller Brake booster??????
Hey guys Im looking to run a smaller brake booster any one have suggestion on what one to run I've seen guys run the 8" from corvette I believe in the past any help would be great thanks
11-11-2015, 03:44 PM | #2 |
Re: Smaller Brake booster??????
Why on earth would you want to run a small booster for?
11-11-2015, 04:26 PM | #3 |
Call up ABS brakes in orange Ca. Im sure they will hqve something. They got me a small one but for a nova.. im sure they have for more applications.
11-11-2015, 05:24 PM | #4 |
For one to have more clearance between my engine and booster its really close with my LS swap my truck is bagged and I z'd the frame 3' so the engine sits close to the booster.
11-11-2015, 05:26 PM | #5 |
Then switch to hydroboost. I wouldn't sacrifice any braking no matter what in these trucks.
11-11-2015, 05:27 PM | #6 |
Some pics of my truck
11-11-2015, 05:31 PM | #7 |
Post Whore
Great looking truck..but as stated.. go hydro..you won't regret it.
11-12-2015, 07:34 AM | #8 |
Parts and more parts
I would either go hydro boost or if you do get a smaller vacuum booster, get one that is dual diaphragm design.
Frank |
11-12-2015, 07:53 AM | #9 |
I used the smaller dual 8" booster on one of my ls swaps for clearance as well . It has more surface area than the standard 11" booster . May be just a little bit more boost . Mine works great with no ill effects . If you do this only use the dual and you will be fine .
