Old 11-11-2015, 08:32 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Do the inner door handles and window cranks work with the panels off?
71 Chevy
At the moment I'm trying to remove all possible while maintaining start and stop. Would like to hit the door panels next.
Speak of cranks and handles, nearly everywhere I look reads "slip tool between panel and crank or handle." Unless I'm mistaken, isn't it really between the escutcheon and crank or handle for clip removal?
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 11-11-2015, 08:39 PM   #2
hugger6933
Re: Do the inner door handles and window cranks work with the panels off?
Yes it is. the handles and relay will work without the panel no problem. Also here is a little body shop tip from me line up the U part of the clip tool with the handle part of the crank or handle[you know, the part i guess I'd call it the lever part for lack of a better word]. The clip [unless it has been placed wrong] will always line up with the lever part of the handle. No need to spend lots of time searching for the clip. Just line up the U with the lever part and wiggle the tool a little as you push in it will pop the clip right out. Place a rag or you hand on the back side as those clips like to become airborne after gaining freedom. Jim
hugger6933 is offline   Reply With Quote
Old 11-11-2015, 08:40 PM   #3
frenchy51
frenchy51's Avatar
What I do is pry it apart a bit so you can see in with a flashlite and then figure the best plan of attack. You never know which direction it was installed last.....
frenchy51 is offline   Reply With Quote
Old 11-11-2015, 09:10 PM   #4
71CHEVYSHORTBED402
Thanks for the information, sounds good.
